Just priming the oil pump by back filling at the banjo bolt and turning over backwards with the transfer casing not fitted. I notice that oil appears at the bottom of the pump in the semi-circular cut-out where it mates with a hole going through the block.
Never thought about the rear cam bearing lubrication before; The rear bearing only seems to get lubricated by the small hole in the pump face - is this what I'm seeing as a "leak" when priming the pump???
I've pictured the old pump face ; is there sealing between the cam bearing at the bottom where that cavity is or does oil just drain out there?
It's a new pump and gasket on a 998 A+ block; just want to understand if this is normal or a gasket problem? (Sorry - getting a bit paranoid as the build nears completion)
