1988 Mayfair Rebuild (998)
432 replies to this topic
#121 Viktor
Viktor
  • 658 posts
Posted 17 October 2022 - 07:01 PM
Righto so the battery tray wasn't quite what you'd call a perfect fit..
Marked up where it needed to be
cut little slits to assist with the bends
Flatten out the old useless lip
This is where it's a bit tricky because already being a box makes it difficult to get the bends in, can't just use the sheet bender like I would usually prefer, so it's just on the vice to gradually work along the bend and using a hammer to get it tight
Then marking up what I want to keep (use the meat of the existing tabs to create new ones)
Cut off excess, tidy up a bit with the power file and voila:
same with the back side
and trial fit
Ooooo so close
might give the floor a little upwards whack to see if I can close that up, otherwise it's a slight adjustment required, all other edges spot on.
Finish that off another day
Told you! :)
In any case, well done Stuart, that would save me lots of hours wondering what to do. Thank you so much!
Victor.
#122 stuart bowes
stuart bowes
  • 2,631 posts
Posted 17 October 2022 - 07:02 PM
yeah I have to say, you were right :) ah well today's lesson is don't listen to mini spares when they say it fits easily lol
#123 Sunnymini
Sunnymini
  • 14 posts
Posted 18 October 2022 - 07:53 AM
oooohh, power file! sounds like an interesting toy! Dear Santa.........
#124 stuart bowes
stuart bowes
  • 2,631 posts
Posted 18 October 2022 - 09:02 AM
it's a very useful bit of kit for sure :)    I've got a black and decker but I've seen this one recommended and it's a bit less bulky if nothing else https://www.amazon.c...r,aps,84&sr=8-8
easy to get carried away when working on thin sheet though so be careful take it slow till you get the knack of it
really useful for tidying up welds, you can be more accurate than you can with a grinder but it takes a bit longer.. swings and roundabouts
Edited by stuart bowes, 18 October 2022 - 09:04 AM.
#125 stuart bowes
stuart bowes
  • 2,631 posts
Posted 20 October 2022 - 04:14 PM
re-adjusted bend and re-trimmed flange to fit a lot better
close enough now to force the edges together as I weld my way around for a perfect fit
just a bit of final finishing to do now, thinking of welding in small corner pieces so the surround is even and tidy all round, and also just working a few bits with a hammer to tighten up the bends in a couple of places
might as well just leave the old flange in place as it gives a little more strength, and it'll all be smoothed out with a scraping of filler anyway so who's even going to notice
Edited by stuart bowes, 21 October 2022 - 02:37 PM.
#126 stuart bowes
stuart bowes
  • 2,631 posts
Posted 22 October 2022 - 10:55 PM
welding in and smoothing out corner pieces
and then welded up the slits between the bends for one complete flange all round
easier than worrying about trying to close up tiny little gaps after it's already fitted into the boot
Edited by stuart bowes, 27 October 2022 - 09:25 AM.
#127 stuart bowes
stuart bowes
  • 2,631 posts
Posted 29 October 2022 - 10:34 PM
got a bit of the welding done in the boot
ingenious method of pushing the battery tray down on all corners, nothing wrong with a little bit of brute force and ignorance
and tacked in for now to hold it down
not sure how much I'm going to weld this, certainly not fully seam welded all round but I decided against plug welding with holes because the lip is quite narrow and the original hole in the floor actually isn't all that square so Id be welding onto thin air in places
anyway I did this bit of welding
and this bit of welding
which looks like there's little holes, but there aren't, that's just dark shadowy bits and/or where the primer didn't get right in there which doesn't really matter just yet
the other obvious weld from left to right via the wheel well was there when I moved in, previously mentioned as possible rear ender repair
next up, finish off around the battery tray, wheel arches and subframe brackets
then I can start on those big plates underneath
Edited by stuart bowes, 30 October 2022 - 06:47 PM.
#128 stuart bowes
stuart bowes
  • 2,631 posts
Posted 30 October 2022 - 06:40 PM
welding around wheel arch and bracket / finished off the join to the new lower rear boot opening
still to be ground down yet
decent penetration visible from other side
Also did a bit of a clean up on the old valance, still in pretty good nick I think I will reuse
ends starting to show age (ironically the bit behind the closing panel which is supposed to protect from rot?
outside face is good
Kurusted the inside
and zinc primered both sides
lots of work to be done on that before fitting obviously
Edited by stuart bowes, 30 October 2022 - 06:43 PM.
#129 stuart bowes
stuart bowes
  • 2,631 posts
Posted 03 November 2022 - 08:29 PM
Bit of work on the rear valance
Replaced the section where my angle grinding went a bit off-course during removal
Replaced the section where the fog light fixing holes somehow ended up massive (kept the hole for the cable which will be grometted obviously)
And filled the small holes where the old arches were self-tappered
Smoothed that all down enough that a scrape of filler later on will sort it out
And then also filled in where there was a little curved cut-out for the exhaust, didn't seem necessary and might go centre exit anyway who knows.  rather do it now than trying to faff about with it on the car
Now I just need to tidy up the curved ends and even up the flange edge a bit
yes, I could have saved time and effort just spending £30 on a non-heritage one, I did consider it, but in this instance it was raining out anyway, I needed something to do in the garage instead of outside, and it seemed like a good way to practise fabrication, why not (nothing wrong with a bit of make-do and mend from time to time)
Edited by stuart bowes, 04 November 2022 - 09:12 AM.
#130 stuart bowes
stuart bowes
  • 2,631 posts
Posted 05 November 2022 - 09:49 PM
plans updated slightly
folded up a little metal box to recess the rear fog instead of hanging it on a bracket like an afterthought
Edited by stuart bowes, 05 November 2022 - 09:49 PM.
#131 Retro_10s
Retro_10s
    Moderator
  • 10,187 posts
Posted 05 November 2022 - 10:02 PM
Without a doubt this is one of my favourite modifications seen on various minis, it's sympathetic to the styling, relatively simple, and way way better than the usual 'bracket' of metal that was standard. Brilliant stuff
#132 stuart bowes
stuart bowes
  • 2,631 posts
Posted 06 November 2022 - 07:55 PM
Cut out valance and mark up box to my best estimation of what vertical is once fitted
I pretty much knew in advance the bottom edge would be minimal but ended up none at all.  probably for the best, one less place for water to sit
Fit it and realise due to curvature the top end doesn't line up right
Finish the welding, grind down, prime with the top edge masked off and cut the top off
Fabricate new 'lid' section which closes in the top, gives me a little lip along the top edge, and spaces it out enough to not foul the boot floor (hopefully)
welded it on but should have taken a bit longer over it
I know this is a total dogs dinner, I just wanted to get it on quick before going out but I should have just left it for later really, lesson learnt
The front side looks ok though
Edited by stuart bowes, 28 November 2022 - 01:25 PM.
#133 stuart bowes
stuart bowes
  • 2,631 posts
Posted 07 November 2022 - 09:03 PM
Again from a better angle so it doesn't look wonky (weird camera perspective)
Can probably paint the black part body colour as well to blend it in nicely (although it's planned to be a dark colour anyhway)
I tidied up the back side a lot
and smeared a load of filler around the seams just to stop any damp getting in while driving along
which I'll tidy up, prime again and obviously all will be lavishly smeared with underseal
And building up the ends where the grot had to be cut off
I will leave the flanges off till it's being actually fitted so I can make them line up with the body seams more easily
*** EDIT all of this was later deemed too sh.t for real use (decent practise though I guess) and started again around the page 21-22 ish mark ***
Edited by stuart bowes, 28 November 2023 - 08:43 PM.
#134 elliot341
elliot341
  • 214 posts
Posted 08 November 2022 - 08:41 AM
Looks good for the fog light, might be better to smear seam sealer round the back of it than filler to give it a little flexibility, but probs be ok.
#135 stuart bowes
stuart bowes
  • 2,631 posts
Posted 08 November 2022 - 09:35 AM
cheers, yeah that's probably a good point, I was in two minds about it to be honest, either way it's better than having gaps I suppose lol  mainly I didn't see the point of getting all carried away with lots of welding when it just wasn't necessary
Edited by stuart bowes, 08 November 2022 - 09:36 AM.
    Bing (1)
