1988 Mayfair Rebuild (998)
407 replies to this topic
#61 stuart bowes
stuart bowes
  • 2,075 posts
Posted 15 July 2022 - 08:03 PM
Edited by stuart bowes, 11 April 2023 - 02:03 PM.
#62 stuart bowes
stuart bowes
  • 2,075 posts
Posted 21 July 2022 - 11:14 PM
quick 3d print, replacement part for back part of key lock
pen playing the part of the lock lever, pretty simple and therefore very little to go wrong
angles modelled in a CAD assembly first so should be ok, lever will need an extension adding and possibly a little adjustment to work perfectly
tempted to add springs in both directions to center the key after each use for easier removal.. not sure if necessary and possibly just an added complication that can go wrong
may cut a metal plate and bond to the back side to stop any deformation in hot conditions which is a weakness of 3d printed items
Edited by stuart bowes, 21 July 2022 - 11:20 PM.
#63 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 22 July 2022 - 06:40 AM
Looks like you're making good progress!
#64 stuart bowes
stuart bowes
  • 2,075 posts
Posted 22 July 2022 - 08:42 AM
haha the thought did cross my mind
didn't actually get around to testing it by the time print had finished it was pizza time
Edited by stuart bowes, 22 July 2022 - 08:43 AM.
#65 stuart bowes
stuart bowes
  • 2,075 posts
Posted 22 July 2022 - 04:38 PM
well that didnt work  :lol:
the idea was nice but I couldn't extend the lock latch lever bit and still get it through the hole in the side of the door..
gone back to the original type with linkage rod but the tab part needs to stick out to the side instead of down so I still need to print one
update: this works perfectly.  but I will add a second linkage hole at the red dot for the addition of central locking
passenger door will not have a lock barrel, so actuator would link directly to the lock mech
Edited by stuart bowes, 23 July 2022 - 11:13 AM.
#66 stuart bowes
stuart bowes
  • 2,075 posts
Posted 27 July 2022 - 01:26 PM
day off work today and the missus has taken the kids to Wales for the week
outer sill now on:
before fitting, sprayed the edges where welds go with weld-through primer, then when dry masked that off and painted the rest with underseal containing waxoyl.  was half expecting smoke when welding but none at all which was nice.  will also spray waxoyl in there later after all painted etc
plug welded along the edge of the step and the bottom of the flitch panel, went on nice and easy, left the underside free for now to allow a bit more flexibility when fitting the rear quarter
Edited by stuart bowes, 27 July 2022 - 09:05 PM.
#67 stuart bowes
stuart bowes
  • 2,075 posts
Posted 28 July 2022 - 07:35 PM
time to remove the last of the A panel (wasn't ready to leave the wing free to bend before this point)
cleaned back to shiny metal and a coating of kurust:
In removing the remains of a grotty closing panel I did find a hole hiding at the top of the flitch panel which I ground back to find solid edges and welded a patch into.. not the easiest of locations but isn't that always the way... a bit of scuttle surgery for access.  it's not beautiful but it won't be seen, I put more effort in on the inside
have ordered a repair section for the end of the scuttle and a new closing panel obviously, mean time everything is now cleaned up around all the edges and ready for welding, will leave the A panel off for easy access while I finish that off
Edited by stuart bowes, 28 July 2022 - 07:47 PM.
#68 stuart bowes
stuart bowes
  • 2,075 posts
Posted 29 July 2022 - 08:19 PM
scuttle reconstruction surgery complete, with a teeny skim of cosmetics to help out a bit
as with other bits so far this is only the first go-over - obviously when it comes to painting there will be a higher level of attention paid during preparation
panel gap not ideal but that's how it was when I moved in, can't do much about that unless wing is replaced which is still being debated
next up, weld in the closing panel (awkward), fit the A panel (easy) and then flip it round and start on the other side
Edited by stuart bowes, 29 July 2022 - 08:22 PM.
#69 stuart bowes
stuart bowes
  • 2,075 posts
Posted 02 August 2022 - 08:18 PM
closing panel fitted (underseal with waxoyl in painted above and on top side, tacked in 6 places around the edges) definitely not going anywhere although admittedly I would have preferred to have plug welded all round it... just too awkward for access and didn't seem necessary to be honest
painted on the lower side as well although that will get another going over later, just made sure I got right into all the corners
A-panel fettled and fitted, edge folded to A pillar, undersealed / waxoyled the inside edges there as well to give a decent bit of future-proofing
grinding to be done another time
Edited by stuart bowes, 02 August 2022 - 09:05 PM.
#70 colinf1
colinf1
  • 1,009 posts
Posted 02 August 2022 - 09:31 PM
I agree with the grinding to be done another time! Can usually end up spending more time getting bogged down with grinding, makes you feel like your not making any progress!
Keep at it!
#71 sonscar
sonscar
  • 2,981 posts
Posted 02 August 2022 - 09:39 PM
Don't forget the little reinforcement over the a panel/wing join,Steve..
#72 stuart bowes
stuart bowes
  • 2,075 posts
Posted 03 August 2022 - 09:19 AM
Ah now I was going to ask about this.. the little square hole on the edge was previously 'repaired' (i thought 'bodged' to be honest) from behind with a little 90deg folded piece of steel welded from behind.  is that normal then
obviously I wouldn't buy one I have plenty of spare sheet metal more than enough to make that
#73 sonscar
sonscar
  • 2,981 posts
Posted 03 August 2022 - 09:49 AM
Yes that is it to reinforce the joint,Steve..
#74 stuart bowes
stuart bowes
  • 2,075 posts
Posted 03 August 2022 - 10:12 AM
fair do's I will do that then, it's only a 20min job
cheers
Edited by stuart bowes, 03 August 2022 - 10:12 AM.
#75 stuart bowes
stuart bowes
  • 2,075 posts
Posted 10 August 2022 - 06:40 PM
Span car around and now working on near side
Outer sill off and tidying up mess underneath, not as bad as off side
have cut out the rusy parts already
I've cut off the rear subframe lower captive nut again, I could see straight away it was corroded (top one fine as it was on the other side) and this way the added bonus is I can clean up behind it
some work to do here before welding in the patches and putting the new sill on.  probably gonna do A panel this side as well after seeing the grot that was hiding underneath the other side, even though actually it looks ok, but why do half a job.  It's probably the easiest panel to fit and it's under £30
