1988 Mayfair Rebuild (998)
408 replies to this topic
#391 stuart bowes
stuart bowes
  • 2,095 posts
Posted 07 September 2024 - 07:21 PM
the first application of actual body-coloured paint has occurred - we are going with BRG
just rattle tins in the arches and on the sill for now
pics as painting in process - I ended up using 3 tins to get a good even 4 coats for this side.
just over 2 tins for about 3 coats did seem like it was enough, but I didn't want to skimp on it so I finished off the 3rd tin for good measure
using these paints. I don't know about 'recommend' as such as I'm no expert but the spray pattern was wide and even, and the nozzles didn't block so they worked well
a note on the surface finish for anyone who was curious after I painted the gravitex on by brush:
the brush strokes are fairly obviously visible, I would have preferred a sort of 'stippled' or grainular kind of finish but I'm content with it as it is (protection from the elements being the main concern in these areas)
others might prefer to focus a little more on the direction and evenness of brush stroke for the gravitex, if that sort of thing concerns you
Edited by stuart bowes, 07 September 2024 - 08:06 PM.
#392 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 08 September 2024 - 09:29 AM
The Sprite type manifold is normally a 20 degree angle, and they have matching 20 degree fuel bowl angle adapters. Minis normally use 30 degree manifolds and fuel bowls for a bit more clearance
#393 stuart bowes
stuart bowes
  • 2,095 posts
Posted 08 September 2024 - 10:47 AM
Ah that's useful to know thanks, will look further into that much appreciated
#394 Sunnymini
Sunnymini
  • 14 posts
Posted 10 September 2024 - 10:14 AM
read from start over last 2 days at work ahahahhaha, making good progress! its looking good.
#395 stuart bowes
stuart bowes
  • 2,095 posts
Posted 10 September 2024 - 10:36 AM
cheers :) were the pictures loading ok?  I've noticed imgbb can be a bit hit and miss, starting to think of using a different server
#396 Sunnymini
Sunnymini
  • 14 posts
Posted 10 September 2024 - 01:46 PM
yeah didn't have any issues, all ok.
#397 stuart bowes
stuart bowes
  • 2,095 posts
Posted 02 November 2024 - 04:36 PM
Been a bit busy lately but time for an update such as it is
Turned car over to other side, cleaned out and wirebrushed front wheel arch, kurusted for good measure although nothing more than surface rust found
made the arch/A panel joining piece same as the other side, welded in
gave it a good seam sealing, using the much easier method of rubber glove and smearing it in with fingers (using a brush just makes a lot of mess)
and then today I finished off the stone chip on that side (brushed on again as before)
once that's dry I can do the BRG paint, rub down and re-paint a few bits of the black truck bed paint that didn't go on as nicely as I wanted, get the edges all tidied up with with a small brush just because I'm pedantic like that, and we can start fitting pipes ready for the subframes to go on
in the mean time, I did also give the old wheels a bit of a clean up and had some new (old) outdated tyres from ebay fitted just for the purpose of rolling it around later on.  the tyre man wasn't really happy about fitting them and I had to assure him they would never see use on the road, that's fair enough really he was just doing his job
I didn't want to go straight to new tyres because a) they'd be sitting around for ages getting flat spots and getting old for no reason b) they're expensive and c) actually I'm not sure if I'm even going to be using these rims
Edited by stuart bowes, 04 November 2024 - 01:57 PM.
#398 Rubbershorts
Rubbershorts
  • 324 posts
Posted 29 January 2025 - 01:30 PM
Hi Stuart. Just doing a similar thing with my rear arches. Have you finished them just in the spray cans paint, or did you lacquer afterwards?
Thanks, Daz.
#399 stuart bowes
stuart bowes
  • 2,095 posts
Posted 29 January 2025 - 01:52 PM
I actually haven't done a clear coat, no, I've been thinking about it though
currently both sides are painted green, and it's still up on its side ready to be dropped down and subframes fitted (pipes are on)
it's a good question, I might well put some on yeah
Edited by stuart bowes, 29 January 2025 - 01:52 PM.
#400 Rubbershorts
Rubbershorts
  • 324 posts
Posted 29 January 2025 - 02:35 PM
Another option I've been considering. There's a build on here somewhere, can't find it again to give more details, but the guy has brushed on a true two pack spray paint for added resilience. I popped down to our local paint supplier to buy some but it wasn't an option in metallic paint for some reason. He said an alternative would be to choose a very close solid colour instead, as this wouldn't really show under the car. I already have some rattle cans of my colour so I'm torn between the two. Metallic with a lacquer, or a close solid colour two pack, brushed on. He did say that he didn't see much point in the lacquer in that area. People say a lot of things though, hence my question.
Edited by Rubbershorts, 29 January 2025 - 03:18 PM.
#401 stuart bowes
stuart bowes
  • 2,095 posts
Posted 29 January 2025 - 02:44 PM
Exactly that yeah I'm debating if there's any point as well
#402 stuart bowes
stuart bowes
  • 2,095 posts
Posted 08 March 2025 - 02:42 PM
some time has passed.. work/kids/college/cold weather, take your pick ..
getting back on it a bit now, finished off the paint underside, no I didn't do any clear coat (yet ?) but all of that is going to be lanoguarded or similar so I'm not massively concerned about protection or finish
I also sorted out the fuel and brake lines (battery cable to go in later after subframes)
Then I had to work out how to get it back down again and move it around without mucking up the paint.. so I came up with this, few cable ties, strips of wood and cut up kneeling pads
4 of them made up, car back down again, next job get it up on stands.. but first had to run to the tip and throw out all those old tyres, and just a general tidy up / sweep the area etc
(and find somewhere better to put my bike which is just getting in my way)
Edited by stuart bowes, 08 March 2025 - 05:03 PM.
#403 stuart bowes
stuart bowes
  • 2,095 posts
Posted 08 March 2025 - 05:42 PM
got it up on the stands .. made some wooden blocks to suit the profile of the stands and cable tied on for a bit of added security
bit of sticky back foam padding as a topper
got it up to a nice working height
and after I adjusted it so those front stands aren't resting on the dipped part of the footwell, ,spirit level inside shows level across crossmember widthways and along floorpan lengthways.  same on parcel shelf. bulkhead crossmember, front panel, etc seems that nothing's wonky, at least not way off
annoying that in the pics there are random patches of light that make the paint look all patchy and uneven in places... it's not, they're just reflections
next jobs;
  • finish painting inside engine bay
  • prep and paint in footwell, just the areas where the pedal box / frame and rack mounts are
  • fit rack, fit subframes, fit parts necessary to get brakes working and tested (and checking for leaks) before doing anything anything else
Edited by stuart bowes, 11 March 2025 - 10:46 AM.
#404 stuart bowes
stuart bowes
  • 2,095 posts
Posted 08 March 2025 - 07:38 PM
also annoying me which I've just noticed, the brake line and fuel line are not curved symmetrically which is really bugging me lol
Different bend radius' for different sizes of pipe, I guess
I'm not going to mess with it though, just have to wait until it's hidden by subframe and rack and I manage to forget somehow
Edited by stuart bowes, 08 March 2025 - 10:07 PM.
#405 colinf1
colinf1
  • 1,013 posts
Posted 08 March 2025 - 10:28 PM
Looking good Stuart!
Hopefully you can get a good run at it now that the weather is (hopefully) getting better and you've a bit more time in the evenings!
