1988 Mayfair Rebuild (998)
432 replies to this topic
#316 stuart bowes
stuart bowes
  • 2,631 posts
Posted 01 December 2023 - 07:38 PM
Righto so the new valence and recessed fog light (round 2)
traced out the curve using the closing panel (which I hoped wasn't too far off despite having magnum written on it ..)
checked it, good enough for this purpose at least
worked out the depth of recess I want as a cross section
plotted that out as a box (allowing some extra and knowing I only needed 3 sides
cut that out and folded it
then obviously weld that up
mark up where the closing panel ends
use template to mark out top and bottom points of cutout
plot that out to the right width
nervously cut the bottom half first so I can slowly work the piece in and check the top positioning, turns out it was spot on, bonus
check position overall from the other side, happy with that
do what I probably should have done first and check subframe clearance (loads of room, I thought there would be)
mark up the box ready to trim down and weld in
part 2 to follow hopefully not making a total mess of the new valance
leaving top edge on for now to assist with rigidity during careful slow welding.  trim off after leaving just the very ends as previously mentioned
Edited by stuart bowes, 14 December 2023 - 07:13 PM.
#317 stuart bowes
stuart bowes
  • 2,631 posts
Posted 02 December 2023 - 01:25 PM
trimmed to size, cleaned up all edges and tacked in
welded in, 3 sides match up nicely one side has a bit of a wonky gap, needed some lumpy welding to fill
used closing panel to check the curve is still ok
smoothed outside edges
gave it a dash of etch prime just to cover it for now
outside needs a bit more work with the power file (When the new one gets here, old one died) and then possibly a couple of small smears of filler to finish.   Inside will just be covered with seam sealer anyway like everything around it, so not a lot of point wasting time trying to smooth it out, and it's not that bad anyway
much much better than first attempt that's for sure
Edited by stuart bowes, 02 December 2023 - 01:26 PM.
#318 stuart bowes
stuart bowes
  • 2,631 posts
Posted 03 December 2023 - 07:52 PM
welded in the rear subby fixing holes and redrilled in the right location.  Heelboard is unchanged so that's my fixed point of reference that I'm calling 'correct' (or as close as their tolerances were in those days) so the rear holes being wrong must be due to whatever I did to the boot floor
drilling was extra hard work due to those big old 1.5mm strengthening plates (2 layers) but got through with a bit of persistance
on the passenger / fuel tank side the new holes are still fairly central on the wheel arch bracket and happy to leave them.  on the drivers side the holes are now off centre to the point where one is nearly off the bracket and the other you can't get the head of the bolt all the way down from above.  so that bracket obviously has to come out again, I'll probably just order a new one instead of trying to repair it, they're not expensive
anyway the main thing is I can now get all 8 bolts in at the same time which I'm calling progress
also, cut off the first of the slinger brackets and looked underneath, some minor welding to repair cutting marks and 3 spot weld holes but nothing problematic
I'll make that the next job
Edited by stuart bowes, 03 December 2023 - 08:31 PM.
#319 stuart bowes
stuart bowes
  • 2,631 posts
Posted 04 December 2023 - 06:58 PM
only getting short bursts of work in at the moment, cold outside / work / kids etc
but every little helps
trimmed down this corner that was annoying me every time I looked at it
(a little note to self in case I forget to weld up that seam.. and yes I will definitely be tidying up welds before paint. still haven't mastered getting it on neatly yet)
then chopped out the bit that needs replacing
Edited by stuart bowes, 05 December 2023 - 08:23 PM.
#320 Be87n
Be87n
  • 22 posts
Posted 08 December 2023 - 09:09 PM
Nice solution! Just deleted fog lights and reverse light on mine but like your approach if you don't want the rather ugly lights hanging about below the bumper.
Edited by Be87n, 08 December 2023 - 09:10 PM.
#321 stuart bowes
stuart bowes
  • 2,631 posts
Posted 08 December 2023 - 09:21 PM
cheers yeah I always thought the fog light looked like a total afterthought, recessed into the curve like this it sort of matches the style of the other rear lights doesn't it, or that's the idea anyway
someone should do that as a pre made type of valance I reckon it would sell. I would have bought one anyway
Edited by stuart bowes, 08 December 2023 - 09:21 PM.
#322 Designer
Designer
  • 760 posts
  • Local Club: LSMOC
Posted 09 December 2023 - 05:49 AM
Stuart I fully appreciate that in your project, which is amazing work and a joy to follow that you are not going for originality but certainly safety.
To me the placing of the rear fog light, as it is, is part of the time line of the Mini, meeting the regulations at the minimum of cost.
This seeming to be the Mantra of BL, BMC or Rover, whichever, that helped to make the Mini so quirky and lovable.
Looking forward to your next update.
Paddy
#323 stuart bowes
stuart bowes
  • 2,631 posts
Posted 09 December 2023 - 10:47 AM
Yeah i can appreciate the preference for originality even though its not for me really, I'm sort of halfway with it, I don't like the fully deseamed look and I wouldn't do any sort of max power crazy spaceship looking interior or anything but I won't shy away from minor 'improvements' (IMHO anyway) like the flush door handles, trying to get the bonnet to open to a normal height, putting anything chrome firmly in the bin where it belongs lol and this flushed in fog, the de seamed front and back (bumpers can easily be retro fitted with a few brackets) and probably a tastefully done dash with touchscreen infotainment.. remote central locking just because convenience..
I suppose in a way the mini was victim of its own popularity, because everyone loved the simplicity and quirky cute styling bmc / rover etc were scared to change anything dramatically (and/or unwilling to spend money) so it kept a lot of its foibles (including let's be honest a long overdue engine upgrade)
Whereas the fiestas and corsas for example being in competition for sales and no one being particularly tied down to one style meant they got endless revisions and improvements
Having said that I do love a mk1 fiesta. Can't take the dagenham out the boy etc
Edited by stuart bowes, 09 December 2023 - 10:55 AM.
#324 stuart bowes
stuart bowes
  • 2,631 posts
Posted 10 December 2023 - 07:24 PM
slightly longer update today
cut the piece to replace below rear left light cluster
put the fold in one end then realised I didn't cut quite wide enough due to curvature.  oops.  never mind, make in 2 parts and weld back together:
plug weld at seam and weld along top edge, flush off and prime
top corner looks a little off but that's actually where I cut the floor piece back too far, the important thing is it aligns well with the quarter panel (checked from behind as well) I did also straighten out that little kink right by the seam
so I flap disked back the edge until I had a reasonably straight even gap (maybe a little too much actually but no problem)
welded the top and ground off nice and flat from both sides to keep a nice sharp edge
got the bottom lined up right and then welded in all round including to the new hinge panel which was sitting there just tacked for ages
it's not exactly beautiful but it's solid, some dremmelling and fine sanding later to finish that off (And obviously as with the rest some tidying up on the inside)
tacked the rest and checked alignment
all good, welded up and smoothed off, primed and done (for now..)
then I sorted out this bit where I'd removed the slinger bracket.  Welded in that circular hole while i was at it
and that's it for today
next up, same side front slinger bracket removal and tidy up, then sorting out behind the front suspension bracket point as is tradition
Edited by stuart bowes, 29 June 2024 - 06:17 PM.
#325 stuart bowes
stuart bowes
  • 2,631 posts
Posted 13 December 2023 - 06:57 PM
removed outer layer of front near side shock mount
made sure to only cut through in one place and the rest was just deeply scored, such that I peeled it out like opening a tin of spam.. that way I knew I hadn't gone through to the layer below apart from in one place.  when I weld in the new bit I'll turn up the welder and make sure I penetrate right through
anyway the layer below looked like this so I was happy
soaked it with Jenolite and just lobbed on some primer for now
will be painted, then the new piece bolted in, then wire brushed just around the edges and welded, best I can really do for protection I guess
next up removed the front slinger bracket and cleaned up, more Jenolite and then primered temporarily
last pic showing side angle as you can see it's suffered from the classic 'jacking in the wrong place' syndrome and needs some hammering to flatten out as much as possible
Edited by stuart bowes, 13 December 2023 - 06:59 PM.
#326 stuart bowes
stuart bowes
  • 2,631 posts
Posted 16 December 2023 - 09:24 PM
made piece to replace cut out in front arch
primed and painted the inner faces, left overnight, only had black at this point but makes no odds I guess
following morning bolted into place and tapped down the edges a bit, make sure all flush.  wire-brushed good and hard right into the gaps to ensure bare metal for welds (minimum possible left unpainted)
welded in and linished back
in the process I actually got one of the bottom bolts stuck in and snapped the head on removal but as it turns out, when working out how to deal with that I realised I can cut out the bottom retaining threaded bar (underside) and also get to clean up better behind it anyway, two birds one stone (the area does need some attention)
primered to check progress and marked off / ground back areas that need a bit of extra weld (top bolts left in a little to protect those threads from weld splatter)
linished and primered end result, that'll do nicely for an area that will be permanently hidden by a big bracket and all surrounding areas covered with stonechip and paint anyway (arguably I put too much time and effort in all things considered)
and finished off the afternoon's work by cleaning back to bare metal, kusrusting and primering this section.  including what isn't obvious from the picture, grinding and filing off those captive nuts around the air intake of which 3 had snapped off bolts stuck in
eagle eyed may also spot a patch of primer to the underside of the wing, that's where I'd welded in the aerial hole.  already smoothed over the top side, now also done the underside
nearly ready to flip it over to the other side now just a bit more cleaning up to do which is easier from this angle
Edited by stuart bowes, 17 December 2023 - 07:16 PM.
#327 stuart bowes
stuart bowes
  • 2,631 posts
Posted 23 December 2023 - 07:49 PM
Car is back down flat again and I can remove this bracket where the holes got welded up and re-drilled
bit of a mess at that point, taking time to remove carefully and not do any damage, but you can see where the new hole positions would have been no good .. also when I put the new one in, having had a bit more practise now I can do a neater job seeing as this is the really visible side
gonna refit the subframe as well to be doubly sure before welding in again, not making that error twice lol
couple of spots of welding probably required on the arch you can see at least one place I've dug in too much
tidying up other welds in same area a bit as well although that's really a finishing up job for later
Edited by stuart bowes, 29 June 2024 - 06:19 PM.
#328 stuart bowes
stuart bowes
  • 2,631 posts
Posted 24 December 2023 - 11:51 PM
some further detail on the bracket removal, not massively exciting just taking time over doing it as carefully as possible
what I've found as a useful method for grinding accurately is to occasionally spray over with some primer
that way you cover up all the existing tool marks and can use the new ones to aim accurately (even more relevant when working in an awkward corner at weird tool angles)
and that stops me from grinding in the wrong place too much and thinning out good metal
then every now and then another spray over.  which also helps to make the remaining work easier to judge
the bracket itself is pretty much gone now it's mostly just weld around the edges to remove now, nearly there
when I did try the new bracket pushed up to the wheel arch correctly I found a good position where the front/back alignment is ok, but left/right needs the holes welding up and redrilling which I'm fine with (subject to refitting subframe first and double checking before doing any work on it)
Edited by stuart bowes, 24 December 2023 - 11:58 PM.
#329 stuart bowes
stuart bowes
  • 2,631 posts
Posted 26 December 2023 - 08:41 PM
subframe fitted again and double checked all the holes align correctly .. they do
showing alignment of left side bracket holes after redrilling.  as you can see they did end up slightly off centre from original, but perfectly functional no need to replace on that side:
Still a lot of weld tidying to do there I know (you can clearly see the penetration from those big plates on the underneath as well which is pleasing)
so, right side bracket, welded up the holes after checking centres (57mm in case anyone wanted to know) and primered, and then marked up the floor hole positions for ease of locating with some degree of accuracy (as you can see this isn't a micrometre job lol)
used those marks to find a good position and mark the bracket
redrilled holes (8.5mm in new money) and trial fitted, happy with that, again they're not perfectly centered but they will be perfectly functional and what part on a mini ever was aligned correctly, call it an homage to originality
a bit more fettling and slight reshaping of edges required, and finishing off on the removal of old weld on the floor and arch, then can fit it
painted the inside as well (black again not that it matters) as a layer of protection
looking forward to making progress again instead of two steps backwards correcting a mistake .. doh
Edited by stuart bowes, 26 December 2023 - 09:29 PM.
#330 stuart bowes
stuart bowes
  • 2,631 posts
Posted 27 December 2023 - 05:09 PM
finished off grinding back the old mess, went a bit overboard with the paint for some reason and then fitted bracket
wirebrushed all around area with bracket in place, did a bit of tapping into shape to make sure edges all meeting up with arch
welded and primered again
still not the prettiest of welding, it's just such an awkward angle to get in at, will have to just grind back when I get to that point doing the rest of the boot floor
anyway, now that's done I can take subframe back off and get it back over on the other side to start making progress again
beginning with tidying up the plug welds on that side of the outer sill, a few little dabs of filler required there from when I was trying to plug weld upside down .. or i might go over it again with the welder I suppose, structurally I'm sure it'll make zero difference
Edited by stuart bowes, 27 December 2023 - 05:16 PM.
    Bing (1)
