1988 Mayfair Rebuild (998)
432 replies to this topic
#211 stuart bowes
stuart bowes
  • 2,635 posts
Posted 09 June 2023 - 06:39 AM
Lol yes sorry I should have specified, a method that gets the job done in under a year
#212 johnR
johnR
  • 2,322 posts
Posted 10 June 2023 - 10:09 AM
Any chance of posting your pics with imgur? - it would be great to see them easily.
#213 stuart bowes
stuart bowes
  • 2,635 posts
Posted 10 June 2023 - 11:14 AM
bit awkward that because my main collection here is all 2mb files, to post them online I crop and resize to 900px wide, then after all the uploading I delete those smaller versions
so I would have to go though what is now hundreds of pictures either uploading big versions which would take ages or resizing them all again which would take even longer
was there any particular are you wanted to see because I could maybe upload a batch to a public Gdrive or something
Edited by stuart bowes, 10 June 2023 - 11:15 AM.
#214 stuart bowes
stuart bowes
  • 2,635 posts
Posted 13 June 2023 - 08:26 PM
continued work on the rear parcel shelf, decided I want 6x9's and so obviously the best time to do the cutting etc is right now
after checking with fuel tank for clearance, traced out shapes including removal and plating-in of the two inner holes of unknown purpose (old mono speaker setup maybe? whatever it was, not wanted now)
I didn't want to cut too close to the edges of the pressed in strengthening dimples because a flat surface is easier to linish off, so I was left with a little bit of the flange from the small circles.  grips to bring them level and a hammer and dolly soon sorted that out
the air saw made light work of the 6x9 holes
and to get rid of the remains of the adjacent dimpled sections I cut relief slots
and clamped them flat followed by a bit more hammer and dolly
same both sides, obviously
eagled eyed will notice I also dealt with those little D shaped holes by cutting them out into a easily fillable triangle shape
traced filler shapes and made in steel
used a length of RHS and two bits of copper pipe hammered flat to hold the shelf flat while welding up the two slits from earlier
and tacked in the replacement pieces
you may notice with the small triangles I have allowed myself some metal to weld out onto this time, instead of blowing out the edge of the oval (which still needs a bit of tidying with sanding drum but actually came out pretty much spot on so I don't want to ruin that)
that's most of the superfluous holes gone, and two good holes added
next chance I get will finish that all off, flush and primer
Edited by stuart bowes, 13 June 2023 - 08:43 PM.
#215 stuart bowes
stuart bowes
  • 2,635 posts
Posted 15 June 2023 - 06:33 PM
one side finished off using the dregs of the gas bottle, literally ran dry as I finished the square piece in the middle
the latest batch of etch primer is a darker grey for some reason not that it matters really
you can still see where the square hole was obviously but after a thin scraping of filler that will vanish
new gas bottle finally turned up 4pm today (ordered thursday last week !?!)  so can do the rest tomorrow
in the mean time having been binging Binky again I noted they used boxster boot hinges for the bonnet, so knowing the original mini ones are a pile of crud I thought I'll have a bit of that.  £10 the pair free delivery off ebay, it's worth that just for the gas struts
annoyingly the triangular bracket gets in the way on a 'real' mini and I really don't want to cut into that so that's out ... however I can copy and modify the design to make it work (i think) .
firing up Solidworks and ordering a pizza..
Edited by stuart bowes, 15 June 2023 - 06:39 PM.
#216 Jarvis_SPI
Jarvis_SPI
  • 56 posts
Posted 15 June 2023 - 08:26 PM
Watching the Boxster boot hinge solution with interest....
#217 stuart bowes
stuart bowes
  • 2,635 posts
Posted 15 June 2023 - 11:44 PM
1st effort... want to take a few more measurements yet and make a mockup, may need some adjustment, but it works in principle
the L shaped piece attached to the bonnet needs trimming off at the end I just noticed, also the bracket on the bonnet itself would need moving back half inch or so, not a particularly difficult task
the bonnet lifts about 1.5" or so before pivoting up and backwards, which stops the rear edge hitting the scuttle, and then should open to vertical which is the whole point,  I just need to check and possibly tweak that to get it right
and I've got to work out where I'm putting the gas strut obviously
Edited by stuart bowes, 15 June 2023 - 11:54 PM.
#218 stuart bowes
stuart bowes
  • 2,635 posts
Posted 17 June 2023 - 02:46 PM
back on the parcel shelf, welding now all completed
I know theres one that warped a bit I did take a hammer and dolly to that afterwards and got it a lot closer to straight (still not perfect)
it's about as good as I can do in terms of welding and linishing especially in this heat and especially considering the whole thing is going to be covered in sound deadening and/or some sort of shelf covering anyway. But I will still give it a skim of filler just to make it a nice flat surface and hide the welds
I'll also have a look into those speckly brown marks underneath as well at some point although I'm pretty sure it'll all wire brush off like most of the ones I've found
Edited by stuart bowes, 17 June 2023 - 02:51 PM.
#219 stuart bowes
stuart bowes
  • 2,635 posts
Posted 01 July 2023 - 11:39 AM
busy with childcare and stuff still at the moment but some small progress being made on the new bonnet hinges
taken about a million measurements, over and over again, remodelled it more accurately etc, reasonably convinced it will work now but there's only really one way to find out
getting one bend in the right place is easy! getting the next one right is much harder.  In the end I found it more accurate to do one bend (with heat, checking for no cracks and welding it up when it happened once)  and then cutting and welding the next angle on and taking endless measurements to check.  got them pretty much bang on I think.  holes drilled when all bends / welds completed obviously because that makes the positioning easier to get right
remaining pieces are flat plate cut outs so that's easier in some ways but still need to weld in some stud (or actually bolts with the heads cut off.. that note at the bottom should actually say M8, I changed my mind but forgot to update that note which I realised just now)
Edited by stuart bowes, 10 July 2023 - 08:30 AM.
#220 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 03 July 2023 - 06:01 PM
Amazing work as always!!
#221 stuart bowes
stuart bowes
  • 2,635 posts
Posted 04 July 2023 - 02:30 PM
cheers let's wait and see if it actually works first haha
I reckon just from initial impressions Im gonna have to weld up and redrill two of the pivot points .. but it is a work in progress I suppose
really I should stop messing about and get back on with welding the underside of the boot floor but it's such a crap horrible job being upside down I'm doing it little bit at a time
#222 stuart bowes
stuart bowes
  • 2,635 posts
Posted 05 July 2023 - 07:13 PM
So.. as you can see the bonnet lifts up, and sort of rotates slightly forward at the bottom, and up and over at the top to a notably higher angle than standard.  I've measured it what must be a million times and I'm convinced the back corner of the bonnet clears the gutter in the up position
up position
(primer ground off in places where I had to make a couple of adjustments)
down position
in the down position though the angle is a bit off so I'm adding a bit of extra meat to that bracket piece to give me fixing positions in the right place.
More finishing off happened after that obviously..  it's way too big but that was the offcut I had knocking about .  I'll mark up and drill positions, then trim to suit
This will mean of course mean losing some of the 'up' angle but I can trim the stopper tab to allow a little more movement and get some of that back
another few hundred measurements taken means I'm also fairly convinced it will clear the wiper motor on the other side as well but that will just be a bit of last minute excitement when I find out one way or another I guess
and welding 3mm steel is so easy! it's actually quite enjoyable being able to just weld rather than fannying about blowing holes
Edited by stuart bowes, 05 July 2023 - 10:00 PM.
#223 stuart bowes
stuart bowes
  • 2,635 posts
Posted 09 July 2023 - 05:58 PM
Hinges completed and primered for now, looking good and as far as I can tell the same both sides (or close enough..)
I decided the best chance to make sure everything's located correctly is to bolt them to the bonnet, and then hide in the engine bay with a torch and a marker pen while my dad puts the bonnet on with good gaps all round, and then after that there's the usual amount of adjustment on the bonnet fixings so a little in any direction isn't a problem
to that end I figured the next job needed to be getting the front subframe off and the car suitably high up in the air
the other upshot is I can now strip down both subframes and get them down to the sandblasters before painting
I was expecting the traditional holes behind the shock mounts but turns out I have only surface rust it seems
that will get a really good angle grinder wire brushing to make sure but looks good initially anyway
and then I removed the original bonnet hinge arms.  Brackets will just stay there in case the hinges don't work, or some future person doesn't like them for some reason
Then I stood there looking at the bulkhead for a bit having a nice cold beer and thinking about possibly welding in a a few of those holes (or maybe just getting a pack of mixed grommets.. I dunno)
I am slightly tempted to weld a flat plate in place of the unnecessary massive rotodip hole which now only serves to let in noise
either way some work is clearly required there to clean back to good metal and protect it for a few more years
Edited by stuart bowes, 09 July 2023 - 07:56 PM.
#224 colinf1
colinf1
  • 1,089 posts
Posted 09 July 2023 - 08:06 PM
The only benefit of the rotodip hole is if you have a center binnacle, you can do wiring of clocks from the engine side. I put some 20mm foam sheet in mine and it lessened the noise coming in, but I'm gonna put more and more on interior side of bulkhead.
#225 stuart bowes
stuart bowes
  • 2,635 posts
Posted 09 July 2023 - 10:57 PM
I will of course have to leave a hole big enough to poke the loom through, but that really only needs to be the size of the big grommet which is, what 45-50mm or so.. I'll have to measure it
I would probably leave a square hole with something like 80mm sides, then have a piece that fits onto that grommet and bolts in.  like the original cover plate, just a lot smaller
or maybe I'll just leave it alone lol there's enough stuff to do as it is
Edited by stuart bowes, 09 July 2023 - 11:01 PM.
