Changing Rocker Arm/shaft Assembly
5 replies to this topic
#1 croc7
croc7
  • 809 posts
Posted 10 February 2022 - 04:10 AM
I know that when removing the head that manuals state to loosen the stud nuts in the same order that they are tightened. Can I get by with just loosening the four rear stud nuts and the rocker adjusters to change rocker/shaft assembly or am I asking for trouble?
Edited by croc7, 10 February 2022 - 05:09 AM.
#2 PoolGuy
PoolGuy
  • 848 posts
Posted 10 February 2022 - 07:01 AM
To have a chance of this working, drain the coolant, loosen ALL the head nuts and then the rocker nuts. I reckon you’ve got a 50/50 of it being successful on a standard engine. I wouldn’t contemplate doing it this way on anything remotely modified.
#3 nicklouse
  • 18,579 posts
Posted 10 February 2022 - 07:37 AM
I have just backed off the adjuster nuts on the rockers and the taken the rocker set off and replaced. If the rocker set is to be off for a while I refit the posts and torque down again. Never had any problems.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 10 February 2022 - 09:57 AM
I would try it, I've done it in the past and got away with it. You must loosen the radiator cap to make sure there's no water pressure to blow through the gasket joint and replace with the new shaft immediately.
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,345 posts
  • Local Club: Amoc
Posted 10 February 2022 - 11:18 AM
Is it just me that is now hearing mission impossible theme tune.
Ratchet in hand.. old rockers off..... new rockers on.... formula 1 style speeds.....
Ta da..... and it is done......
Good luck.... (now try to do it without thinking mini'ssion impossible Theme tune)
#6 panky
panky
  • 1,790 posts
Posted 10 February 2022 - 02:04 PM
Now I'm thinking of the squirrel obstacle course :D
