K20Z4
6 replies to this topic
#1 quagmire
quagmire
  • 74 posts
Posted 02 February 2022 - 11:02 PM
hi all
as the title, anybody out there using this engine? with drive by wire?
#2 quagmire
quagmire
  • 74 posts
Posted 06 February 2022 - 10:20 AM
ill take that as a no then, i was wondering how difficult it would be to use the DBW system in a mini, and would it be possible to adapt the throttle pedal to use the honda pedal sensor. and could you then use the original honda ECU as a type of stand alone engine management system, or would this not work for any particular reason? open to suggestions or advice here.
john
#3 sonscar
sonscar
  • 2,949 posts
Posted 06 February 2022 - 03:25 PM
With the will and the skill anything is possible.With most of its sensors missing and/or not calibrated for its new home I would not expect it to work.DriveBy Wire faults could have catastrophic results if it fails.
I am not saying to not do it but I think more research is needed.Steve..
#4 quagmire
quagmire
  • 74 posts
Posted 06 February 2022 - 07:25 PM
sonscar to be honest i was thinking the same thing, gonna have a look at converting to cable using a different throttle body possibly intake manifold, and engine harness i have read somewhere that it can be done,with parts from the k20a2
#5 quagmire
quagmire
  • 74 posts
Posted 16 February 2022 - 05:39 PM
come on all you honda guys, just a bit of info would be helpful eg what ecu are you using, basic wiring set up, im starting from scratch here, ive decided to scrap dbw altogther and go for the standard cable throttle, then use a mapped after market ecu to run the engine, yes,no?? like i say just abit of basic info on how you lot did yours
thanks john
#6 gav
gav
  • 696 posts
Posted 28 February 2022 - 04:12 PM
Why do you want to use the Z4?
#7 quagmire
quagmire
  • 74 posts
Posted 28 February 2022 - 10:23 PM
because ive got one in the garage lol
