12" Tyres
10 replies to this topic
#1 Spitz
Spitz
  • 1,716 posts
Posted 02 February 2022 - 02:58 PM
I am looking at getting new tyres for my 89  with stock Rover " minilite " type wheels which I believe are 4.5"
Are 165/60 ok to use on these, or should I be using 145/70?  Advantages/disadvantages of each?
#2 cooperd70
cooperd70
  • 726 posts
Posted 02 February 2022 - 03:27 PM
Correct they are 4.5" wheels. I run 165/60R12 Yoko's on my stock Rover minilites (a 1990 car) with no issues. Assuming all suspension/steering parts are std (eg not running lowered dampers/shortened trumpets etc) and not been messed with, you'll have no issues.
They fill the arch better and give the appearance that 10's in the arch over the OEM tire (145/70R12).
They also hold the road better.
They may make the ride slightly harder over the sidewalls of th 145's.
Go for the 145's if it's originality that you're after.
#3 Spitz
Spitz
  • 1,716 posts
Posted 02 February 2022 - 04:05 PM
Thanks very much.
Not after originality.
Car is strictly a road car, no rallying etc.  has a fast road 1130.
Our roads are fairly crappy over here.  I realise the taller 145 may be smoother, but would def like to fill the stock arches.
No suspension changes other than adjustables in the front...but I don't have them too low.  Stock brakes, lower arms etc.
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 02 February 2022 - 11:07 PM
165/60/12 should be OK on a 4.5 inch rim. You have more choice in tyres at that size. If recommend Falken Ziex ZE 912 (possibly superceded to ZE914) great tyre for the price.
#5 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 03 February 2022 - 12:51 AM
Not sure Falkens are still being made in 12s.
#6 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 03 February 2022 - 01:06 AM
The difference in overall diameter is 5mm, so negligible change to the sidewall
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 03 February 2022 - 10:52 AM
Huddersfield might have a set .. their last but all the usual places to look are out of stock and Falken's website don't seem to list any tyres in 12" sizes.
#8 D 'n A
D 'n A
  • 99 posts
Posted 04 February 2022 - 10:58 AM
I'm a huge fan of the Yokohama A539 tyres. I've had Falkens in the past but did not really like them in wet or cold conditions.
#9 cooperd70
cooperd70
  • 726 posts
Posted 04 February 2022 - 11:12 AM
+1 for these...have them on my car 👍👍
#10 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 04 February 2022 - 11:40 AM
never even realised that falken had stopped the 12inch tyre, looks like yoko only option on 12s then.
#11 roblightbody
roblightbody
  • 440 posts
Posted 04 February 2022 - 02:42 PM
For the last 16 years of production at least, the 12" cars were almost all fitted with these, which are now being remanufactured.
https://www.longston...urato-cn54.html
If you want to be original, that's the way to go, however as with most here for a daily driver car I'd recommend the Yoko A539s. Hugely improved grip, heavier steering, as to whether they're more fun, that depends on your viewpoint.
