Oil Pump And Cam Install Questions
40 replies to this topic
#31 sam138
sam138
  • 509 posts
Posted 11 February 2022 - 02:09 PM
Ok right so do some of the chains have less stretch in them when fitted ? which may take up the slack if I swap it over ? for example the limited stretch minispares one below.
2H4905EVO - Mini timing chain duplex limited stretch type (minispares.com)
#32 KTS
KTS
  • 2,420 posts
Posted 11 February 2022 - 03:16 PM
that's certainly possible, but by no means probable
the reality is that every single engine is different ( crank to cam distance, cam & crank sprocket sizes and wear etc) so the chance that any chain you buy is going to be a perfect fit for your engine is very slim
#33 Cooperman
  • 23,276 posts
Posted 12 February 2022 - 01:52 PM
That does look one tooth retarded on the big pulley.
It is wise to always measure the cam timing accurately because some replacement parts can cause a build-up of machining tolerances and end up with the cam being several degrees out.
One of the biggest timing error I have seen was, from memory, about 7 degrees when timed dot-to-dot with a new Kent cam and budget duplex timing gears. An offset Woodruff key soon sorted it out.
#34 sam138
sam138
  • 509 posts
Posted 12 February 2022 - 11:01 PM
Thanks, I’m going to get another non stretch duplex chain and see if this helps with the slack.
It’s my first time using a DTI gauge, please can you guys confirm that the below is reading 3 thou ? As I believe this gauge reads in mm (0.03mm) this picture is my crank end float.
Attached File  EB58D30B-D675-4DE3-A1F3-985578FD6543.png   158.27K   6 downloads
Edited by sam138, 12 February 2022 - 11:01 PM.
#35 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 12 February 2022 - 11:44 PM
3 thou would be 3 thousanths of an INCH, not mm.
#36 Cooper Mac
Cooper Mac
  • 222 posts
Posted 12 February 2022 - 11:58 PM
That DTI is reading 30 microns (assuming that the pointer moved directly clockwise from the 0 and hasn’t done a full rotation or more) or 1.18 thou (0.00118 Inches).
Edited by Cooper Mac, 12 February 2022 - 11:59 PM.
#37 sam138
sam138
  • 509 posts
Posted 13 February 2022 - 08:31 AM
Thanks for the help, so calculating I need 0.08mm on the gauge for 3 thou ? Should the crank have some play then when moved side to side ? Initially had new standard thrust washer set in there at 0.1mm which I now know is 3.93 thou but you could hear the crankshaft move side to side is that correct ?
Edited by sam138, 13 February 2022 - 08:51 AM.
#38 sonscar
sonscar
  • 2,995 posts
Posted 13 February 2022 - 03:20 PM
I hope you mean to and fro along its length?It has float but you would need to check how much.Steve..
#39 Cooperman
  • 23,276 posts
Posted 13 February 2022 - 04:03 PM
Ideal longitudinal crankshaft end float is between 0.002" and 0.005".
#40 sam138
sam138
  • 509 posts
Posted 16 February 2022 - 10:25 PM
I’ve now set up the crank end float as per below which shows 0.08mm or 3.15 thou. Is this ok for clearance?
Attached File  EE108D36-5492-400A-A985-221A4E43A2DE.jpeg   79.18K   0 downloads
#41 Cooperman
  • 23,276 posts
Posted 17 February 2022 - 06:48 PM
3 thou is absolutely ideal.
