What Can, Or Should, I Do With This Early Gearbox?
5 replies to this topic
#1 mmaki
mmaki
  • 50 posts
Posted 18 January 2022 - 02:30 AM
I am trying to figure out how to proceed with my gearbox. It is a '67 3 synchro magic wand 22a1288 case
You can see in the picture the laygear and 1st gear teeth are worn, and the laygear teeth are pitted:
https://imgur.com/a/BivUu6U
The laygear, which I thought read 22A231, but must be a 22G231 from looking at parts lists, doesn't seem to be available.
Basic bearing rebuild kits don't seem to be available either. Perhaps I can piece the parts together but now I am wondering if it is worth the work and money if I can't replace 1st gear.
Maybe I should just put it back together and pretend I didn't look at it.
#2 floormanager
floormanager
  • 687 posts
  • Local Club: Mini Club Sussex
Posted 18 January 2022 - 06:48 AM
The laygear looks like the laygear in my 3 synchro box.  I've retired it from daily use but I do have a replacement to fit.  What do you want to do with it - use it?  You can get a fair few of the parts, just need to shop around.
Not used them..
https://www.ebay.co....OYAAOSwj3NefoNU
Edited by floormanager, 18 January 2022 - 06:49 AM.
#3 Spider
  • 14,856 posts
Posted 18 January 2022 - 07:48 AM
It depends on what the overall outcome is that you are seeking, eg, a period restoration or a Mini to be driven or ??
Personally, for anything other than a period restoration, beyond the diff thrust washers, I'd not even look at it, but just add it to the stack of other 3 Syncho Boxes and fit as first preference, a Rod Shift box and second would be a Remote 4 Synchro.
It's been a little while since I needed to look, but bearings were available. I'm sure I saw too not that long ago someone had new laygears too. Where overhauling these boxes can run in to brick walls I found is mostly around the Synchro Hubs, determining what you actually have and then finding parts for them can be a mission. There was a truck load and then some, changes and revisions to these during production.
#4 mmaki
mmaki
  • 50 posts
Posted 18 January 2022 - 03:08 PM
Not used them..
I did see that ebay listing in my searching however it is listed as a 3 synchro but the text describes it as a 4 synchro kit. Regardless it is a lot of money to put into a transmission that will still have worn gears. There is another 3 synchro laygear that is more common but I haven't found anyone selling this one.
#5 mmaki
mmaki
  • 50 posts
Posted 18 January 2022 - 03:53 PM
I think my best option is to put it back together and hope for the best. I should say I have never driven the car as I got it in pieces. It is a MKII hydro car so I think  it would be a shame to not retain the magic wand shifter, besides, I already cut out the square transmission tunnel of my replacement floor and cut the hole for the shifter and carpeted over it. I don't really want to redo all that.
My issue is that I am in Canada, engines and gearboxes are just not plentiful. Certainly none local.
My intention is to get my Mini on the road in the spring but also keep a eye out for a 1275 engine and gearbox for maybe replacement in a few years, or sooner if things break.
#6 Spider
  • 14,856 posts
Posted 18 January 2022 - 08:20 PM
My reasoning for suggesting a Rod Shift Box is that just about all parts are still available new. The All Synchro Remote Boxes are in a similar boat. Both of these can be fitted up as a Magic Wand arrangement, there was only a thread recently on the Rod type;-
https://www.theminif...can-it-be-done/
I get that you may wish to get the car running and then decide which way to go here, but it is a viable option down the track.
