The Prep And Refinish Of A Late 80S Mayfair @ Mill Road Iow
34 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 January 2022 - 09:56 PM
Hi all.
I've got the next job in and ready to start.
This time, it's a late 80's Mayfair which has had the panel work carried out by the owner.
All of the underside and inside of the car has been finished and its with me for the exterior finishing and paintwork.
Here is what I am starting with.
All work to date has been done to a great standard by the owner but there is still plenty to do.
As the doors dis not come fitted to the car the first task is to hang them and make sure they gap up correctly.
And the bonnet was pre fitted but not closing nicely so a bit of realignment sorted that easily
Nothing wrong with those gaps at all so happy, I removed them again and removed the sunroof
And top dash rail before sheeting up to stop the dust getting inside
The prep will begin next week.
Ben
#2 MikeRotherham
MikeRotherham
  • 976 posts
Posted 15 January 2022 - 08:44 AM
Another very interesting project that I will be closely following. I've missed my regular Mill Road Garage fix now that mine has been returned.
Loving the new light and airy work space.
Edited by MikeRotherham, 15 January 2022 - 08:45 AM.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 January 2022 - 11:09 AM
Cheers Mike.
#4 Viktor
Viktor
  • 653 posts
Posted 15 January 2022 - 06:30 PM
I will be following :)
#5 Crazy
Crazy
  • 274 posts
Posted 16 January 2022 - 12:36 AM
As usual I'll be following as well looking forward to mine coming to you later in the year Ben.
Workshop looks good too.
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 January 2022 - 06:44 PM
I've started the prep this afternoon.
First thing I want to do is the filler work so I prepped each area with 80 grit on the orbital sander and tapped down any high spots before applying the filler
Some areas around the front of the car had been left bare metal or regular porous primer had been used so there was some rust starting to form in places.
I've cleaned that all back and applied filler to the repair areas.
Ben
Edited by Ben_O, 17 January 2022 - 06:46 PM.
#7 floormanager
floormanager
  • 674 posts
  • Local Club: Mini Club Sussex
Posted 17 January 2022 - 07:22 PM
Another mini getting the IOW Ben TLC!
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 January 2022 - 10:37 PM
Continuing on with the prep, once the base filler work was complete, I qqplied the fine finishing stopper to the repair areas to smooth everything right out, fill in pin holes and blend all the edges
I also flatted back all of the original undamaged paint in the areas not requiring repair.
There was a few bits to do on the back end
And a dent in the roof to repair.
Then I went round reinstating the missing arch mounting holes in the new wing and repair areas
A tip for checking any filler work when you ate happy it feels right is to spray it up with panel wipe and then check by eye.
This way, you can see anything that doesn't look right.
Hard to photograph but you get the idea.
And then after checking round every panel again and again, finding more imperfections and correcting them, it's time to call that it for the first round of prep.
A clean down and damask and its ready for primer
I'm halfway through masking it up so primer will be going on by mid morning I expect.
Cheers.
Ben
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2022 - 01:06 PM
Now ready for primer
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2022 - 08:08 PM
The first thing after degreasing every inch of the car was to apply some acid etch primer to the bare metal areas
Followed by 2.5 coats of white high build
Ben
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 January 2022 - 10:05 PM
Time to block the primer this afternoon.
I started with the front end by applying guide coat.
And then blocked it down
Then moved onto the roof
And then guide coated one aide ready to block in the morning.
Ben
#12 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 January 2022 - 08:53 PM
I've now completed the primer sanding on the shell
Next up, the bolt ons
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 January 2022 - 12:19 PM
I finished repairing the bonnet
Then primed the bonnet
And bootlid
And flatted the primer on both
Then onto the doors.
One required basic prep
But the other one was quite distorted along the bottom which had stretched the skin.
Easily fixed by slight shrinking, straightening and a skim of filler
Once I got those into primer, I marked the car up to paint the roof
And the inside of the bonnet
And bootlid
I'll be ready to paint the rest of the car on Tuesday.
Ben
#14 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 February 2022 - 09:00 AM
Hi all.
Yesterday started with getting this masked up ready for colour.
And then on with the colour
And then once baked, I demasked and rolled it out ready for flat and polish
That's today's Job.
Ben
#15 roblightbody
roblightbody
  • 439 posts
Posted 02 February 2022 - 09:46 AM
Looks incredible!
