The question is, can it work like this? I don't want it to break or damage the speedometer.
Thanks in advance!
Posted 11 January 2022 - 01:58 AM
Posted 11 January 2022 - 03:04 AM
It will work like that but will have a short life. You may find at some (all ?) speeds the needle may not sit steady too.
Posted 11 January 2022 - 07:57 AM
Posted 11 January 2022 - 10:54 AM
usually route mine between carb and rocker cover then over down to gearbox and works fine.
Posted 11 January 2022 - 11:34 AM
Won't be much use on this LHD car though
Posted 11 January 2022 - 02:20 PM
Mine had a ludicrously long speedo cable on it when I bought it. A new one is only €20 or so I'd fit the correct sized one.
Posted 11 January 2022 - 03:00 PM
Posted 11 January 2022 - 03:22 PM
Cheers guys! The cable is 36 inches and yes, this Mini is left hand drive car. A question; Is it convenient to grease the inside of the cable before mounting it or is it not necessary?
Regards, Luis
Posted 11 January 2022 - 06:08 PM
Regards, Luis
I always grease them. They seem to come with a little grease on them, but I feel it's a bit light on.
Posted 11 January 2022 - 06:22 PM
Posted 11 January 2022 - 06:29 PM
Thank you friends! I'll grease it.
Posted 11 January 2022 - 09:56 PM
Not too much .. if it gets dragged up into the speedo it can gum it up!
