Austin Metro 1275 Engine - Upgrade
15 replies to this topic
#1 MartinML
MartinML
  • 27 posts
Posted 05 January 2022 - 02:42 PM
Hi everyone, I'm going to modify my engine. I'm thinking about the following modifications:
Head 12g940:
Lightweight flyweel
Exhaust, manifold from minispares stage one kit RC40-10 - (that i already have) http://www.minispare...c/C-STN18E.aspx
Carb: HiF44, better needle
AIR filter: MED stub stack system with ITG filter
Electronic distributor 65D
pre verto clutch diaphragm orange
minispares clutch plate road/rally - C-AHT595
Facet fuel pump - standard 2.5-3.00psi
Is that a good choice? What power output i can expect? Would you change anything?
Thank you for your advice.
#2 KTS
KTS
  • 2,421 posts
Posted 05 January 2022 - 02:53 PM
the most important component is not listed :  what camshaft ?
#3 PoolGuy
PoolGuy
  • 848 posts
Posted 05 January 2022 - 03:46 PM
Maybe the engine isn’t coming out?
#4 MartinML
MartinML
  • 27 posts
Posted 05 January 2022 - 04:03 PM
Standard camshaft - engine is from austin Metro Vanden Plas. Not Mg metro engine.
#5 KTS
KTS
  • 2,421 posts
Posted 05 January 2022 - 08:16 PM
i'm not sure you'd really need to be using the orange diaphragm; the standard blue one should be up to the job if properly setup, and will be much kinder to the crankshaft thrust bearings/faces
#6 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 05 January 2022 - 09:30 PM
What is the intended use of this car / engine
#7 MartinML
MartinML
  • 27 posts
Posted 05 January 2022 - 10:03 PM
Fast road and some amateur track days. Not daily car.
#8 OzOAP
OzOAP
  • 384 posts
Posted 05 January 2022 - 11:00 PM
Wouldn't waste horsepower by fitting double springs. Std cam and final drive means it won't be reving any higher than std.
Edited by OzOAP, 05 January 2022 - 11:01 PM.
#9 croc7
croc7
  • 809 posts
Posted 06 January 2022 - 07:45 AM
Air cleaner; I think that Vizard did some testing of air filters and had good results with the standard housing (drilled) and a K & N cone filter. Could save you some money. Disclaimer; I have the MED ITG filter and like it.
Roller Rockers; Not sure that the use of roller rockers are necessary for ‘fast road use and occasional track days’ but are fine for “pub points”. Send your rockers to AcDodd for evaluation/modification to an actual 1.3:1 ratio. You will appreciate the increased torque-makes driving the car more enjoyable without revving the nuts off.
Clutch diaphragm/disc; Blue dot should be fine for your use. That’s what I use for my 1360 engine that produces buckets of torque. It seems to me that one has to think about how the car will be used. Unless its a race engine, which is probably rebuilt on a regular basis, use of any ‘high performance’ parts isn’t necessary.
Distributor; I like the choice of the 65D distributor. One of the more knowledgeable contributors to this forum thinks that its the best for the A series engine. For more information, search this forum for use of coils with that distributor.
Camshaft; If you are looking for an increase in performance; consider camshaft, head, intake/exhaust (gas in-gas out). This forum has plenty of expertise to offer advice.
Keep us posted.
#10 croc7
croc7
  • 809 posts
Posted 06 January 2022 - 07:47 AM
Duplicate entry-fat fingers to blame.
Edited by croc7, 06 January 2022 - 09:05 AM.
#11 wile e coyote
wile e coyote
  • 1,230 posts
Posted 06 January 2022 - 08:49 AM
Someone will doubtless be along to correct me if wrong but I think the metro VDP engine was already fitted with the MG metro cam as standard....
#12 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 06 January 2022 - 12:44 PM
You are correct the VDP Engine in 1275 form was the same as the MG Metro so good for around 72HP in standard form. The cam on that isn't too bad for road use, but I would go hotter if the car is only to used for fast road and track days.
#13 MartinML
MartinML
  • 27 posts
Posted 06 January 2022 - 02:00 PM
Unfortunately, the earliest VDPs didn't have a cam and head like the MG Metro. And they produced I think around 60hp. (https://www.vpoc.inf...tro-vanden-plas)
My head has 33mm intake valves and 29mm exhaust valves. So I will be increasing the intake valves to 35.7mm. The exhaust will stay the same.
#14 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 06 January 2022 - 03:45 PM
That might limit the gas-flow you are trying to improve with the head mods ..
#15 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 06 January 2022 - 08:35 PM
The standard size exhaust valve will be fine. If you’re fitting a bigger inlet valve do yourself a favour and cut a multi angle valve seat and back cut the valve. This gives an excellent gain in airflow for the small amount of work/cost involved.
Phil.
