Edit: Just read the Hardi fuel pump introductions and they recommend a filter, as what looks to be standard practice, between the tank and pump.
Edited by croc7, 29 December 2021 - 07:45 AM.
Posted 29 December 2021 - 06:19 AM
Posted 29 December 2021 - 08:08 AM
Posted 30 December 2021 - 10:39 AM
could use standard injection filter that mounts to subframe, but yes it's a pain to change but factory fit if you have to have one. some pumps just have gauze trap on inlet
Posted 31 December 2021 - 06:04 AM
Posted 31 December 2021 - 08:41 AM
Posted 31 December 2021 - 06:52 PM
If you do fit a filter pre-pump with a diaphragm pump, like the SU and Hardi, as hinted at by soncar, if the filter blocks up, the pump will stall in an energised state and burn out in fairly short order. Yes, I am aware what's in the Hardi instructions and surprised they don't include a caution note.
Posted 01 January 2022 - 06:57 PM
Edited by croc7, 01 January 2022 - 07:37 PM.
Posted 02 January 2022 - 12:06 AM
So, reading between the lines, if I place the filter pre-pump, potentially it could clog and cause the pump to burn out. Or, if placed downstream of the pump, there is the possibility of debris from the tank fouling the pump. Didn’t the MKIII Cooper S have an electric pump and if so, where was the filter located?
Our locally produced Coopers and Cooper Ss had no filter at all. According to the Jag guys, the pump can cope with some debris going through it. I'll say from my own experience, with some very dreadful fuel and loads of outback sand & dust, yes, they do cope quite OK.
Posted 02 January 2022 - 01:48 AM
Posted 02 January 2022 - 04:30 AM
Posted 06 January 2022 - 09:04 AM
Out of paranoia I fitted a disposable filter between tank and pump - using a facet cube pump with prefilter anyway - and a cleanable glass filter before the carb - has been in for years and no issues at all - the disposable one next to the tank has caught a few bits but everything is perfectly clean going into the carb - self admitted overkill but effective nonetheless...
