Bonnet Louvres
23 replies to this topic
#16 nicklouse
  • 18,576 posts
Posted 23 December 2021 - 09:57 PM
Vents in the scuttle below the windscreen a la Binky?
Will not let air out on the move.
#17 sonscar
sonscar
  • 2,995 posts
Posted 23 December 2021 - 11:08 PM
Manufacturers put the heater/fresh air vents in the scuttle as it is a high pressure area,or so I was told,Steve..
#18 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 24 December 2021 - 07:43 AM
They also tend to close off the wheel arch areas from the engine bay
#19 Tones61
Tones61
  • 428 posts
Posted 24 December 2021 - 11:00 AM
does this work? back in the day people jacked up rear of bonnet but mixed reviews whether it worked to vent air or not due to windscreen rake, interested to know before cutting into my bonnet
That does not work as a vent on a Mini.
as said by Mr Vizard and proven in the wind tunnel. It also creates lift.
Agreed,
Bonnet lifts---
It only lets out excess heat when stationary,
When at speed there is a high pressure zone at base of windscreen so doesn't
Let out any air :-)
#20 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 30 December 2021 - 10:15 AM
cheers for that, as for binky design bulkhead would get full of water, need to get heat from turbo at rear of engine. ceracote exhaust, turbo blanket, exhasut wrap but any other way of venting heat? dont want to remove inner wing as then rad innefficient ideas?
#21 splintercat
splintercat
  • 616 posts
Posted 24 January 2022 - 05:44 PM
Dont you feel just great when you start a new topic and it goes HOT.............me do.
#22 nicklouse
  • 18,576 posts
Posted 24 January 2022 - 07:56 PM
Need to let air easily out from between inner wing and wing. The panel is in the way. Vent that.
#23 splintercat
splintercat
  • 616 posts
Posted 26 January 2022 - 07:41 PM
loved reading all of this BUT this was meant to be a styling topic, nothing to do with areodynamics???
#24 nicklouse
  • 18,576 posts
Posted 26 January 2022 - 08:13 PM
Then just Do It!
