My '62 Woody rear driver's side suspension went a bit iffy a couple of months ago, dropping so the wheel arch was nearly touching the wheel. I assumed it was the suspension rubber so replaced both rear cones and associated knuckles and readjusted the Hilos. However, after a short drive the same thing happened, with the arch nearly touching the wheel. I now suspect the subframe has given way where the knuckle inserts but will need to dismantle around that area to see if that is the case.
The subframe itself otherwise appears to be in really good condition so I wondered if this was a common issue?
Also, if I do need to replace the subframe are the Minispares or Minisport or other own brand suitable or am I better off getting a genuine replacement?
As always, very grateful for the forum wisdom and advice
Best wishes
Mike
