Hi everyone!
I've been following along a couple other projects on here for a while. After wanting one for several years but not really having the space or mechanical confidence to take one on, I've finally bitten the bullet and bought one!
I bought this in September 2021 but didn't start a thread at the time since I didn't expect it to end up a project, so I'm going to catch up retroactively via a few posts since I have all the photos along the way.
Starting out my wish list was:
- 998cc engine
- Manual gearbox
- Not too messed with (eg, no flip fronts)
- As good condition rust wise as possible (not as fussed about cosmetic paint issues in general)
- Budget of ideally about £6k, but maybe up to £8k for the right car (I regret this, but more on that later...)
- Ideally red, ideally white roof (no sunroof, don't want it leaking)
- Older the better so fewer regs apply
It turned out to be a difficult combination to find: lots of 1275 cars about but few 998s. In hindsight, buying a 1275 and swapping the engine might have been better.
I was really just looking for something I could jump straight into and start enjoying even if it wasn't spot on, and then improve it bit by bit.
Anyway, after a few weeks of searching, here's what I ended up with:
It's a manual 998, it's the colour I wanted, in budget and on the face of it to me (not knowing a great about in detail about Minis) nothing messed with too much. Rust wise, it seems good. Floors look solid, nothing in the way of bubbling visible, except a tiny bit of rust showing in one spot on the roof gutter. Checking all the boxes so far.
Drove a couple hours to view it having not even seen a photo since it was one of the few cars that fit the bill (and the previous few I'd looked at were ruled out for other reasons - generally extensive rust).
On the test drive it clunked a bit (engine steady bushes totally shot) and the brakes were pretty bad. Figured a bleed/new fluid and maybe new shoes/pads might sort that.
10 minutes into the 2 hour drive home after buying it, however, this happened:
It started missing and cut out whilst driving up the M1, and generally felt pretty down on power when we started the drive home to begin with. RAC chap helped us narrow it down to an ignition related issue, suspected the coil was bad.
Replaced the coil the next day, still refused to start. Eventually realised I'd gotten the wrong coil (based on the year it would have been a ballast coil but it turned out not to be). Would up fitting a brand new electronic ignition dizzy, Lucas coil and HT leads, which got it going again and got it home from a friends house after it'd been stuck for a week where the RAC man had dropped it off.
A little over a week after I bought it, it's finally home...
Edited by Hexxeh, 25 October 2022 - 12:27 PM.
