Electronic Ignition Testing
25 replies to this topic
#1 mvahora
mvahora
  • 214 posts
Posted 02 December 2021 - 11:26 AM
Hey guys
I'm trying to test out the electronic ignition on 2 old distributors to see if they are functioning. A 45D with luminition magnetronic electronic ignition and a 23d with an electronic ignition (not sure of brand). Ill be using the test rig as per accusparks video below. My main test battery died last week. All I have now is a small 12V 7AH 20HR battery. Would there be any issue using this for the test?
Edited by mvahora, 02 December 2021 - 11:45 AM.
#2 Ethel
  • 26,782 posts
Posted 02 December 2021 - 12:17 PM
A quick Google says that battery is good for 10 times the current you need.
#3 mvahora
mvahora
  • 214 posts
Posted 02 December 2021 - 11:24 PM
I've got it all hooked up now but I'm not getting a spark when I rotate either dizzy for some reason
I've got 12.9v on the battery
I've got 5.17 ohms (20k option on multimeter) on the spark plug.
Dizzy & Coil both getting 12v.
Not sure what the issue is. Pic below. (I was locked out of my shed so had to improvise on the floor)
Edited by mvahora, 02 December 2021 - 11:27 PM.
#4 nicklouse
  • 19,051 posts
Posted 02 December 2021 - 11:49 PM
See my copied test procedure in the other thread. If you need a larger image just ask.
Edited by nicklouse, 03 December 2021 - 12:36 AM.
#5 mvahora
mvahora
  • 214 posts
Posted 03 December 2021 - 03:24 AM
larger image please. can barely make it out lol
#6 sonscar
sonscar
  • 3,248 posts
Posted 03 December 2021 - 08:39 AM
Difficult to see but is the spark plug earthed to the battery negative.well earthed?Steve..
#7 gaspen
gaspen
  • 1,193 posts
Posted 03 December 2021 - 08:51 AM
Spark plug is not earthed
#8 mvahora
mvahora
  • 214 posts
Posted 03 December 2021 - 09:35 AM
No its not. oh bugger seems like I completely missed that. Putting it between a vice should ground it right? or do I need to attach a wire between spark plug and battery neg terminal or spark plug and ground?
Edited by mvahora, 03 December 2021 - 09:39 AM.
#9 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 03 December 2021 - 10:02 AM
It needs to connect to the battery earth ...
#10 Ethel
  • 26,782 posts
Posted 03 December 2021 - 11:14 AM
Can't see an earth connection on the dizzy body either.
#11 mvahora
mvahora
  • 214 posts
Posted 03 December 2021 - 11:34 AM
There is an earth on the dizzy. its on the vaccuum. black wire. (disregard the dizzy on the right, I was meant to take that out of the picture, its disconnected in the pic)
Edited by mvahora, 03 December 2021 - 11:35 AM.
#12 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 03 December 2021 - 05:17 PM
You might be better off connecting earth directly to the body or the clamp.
#13 Spider
  • 15,830 posts
Posted 03 December 2021 - 05:39 PM
You also need an Earth to the Mounting Bracket of the Coil or at the very least, connect the body of the spark plug to the Mounting Bracket.
#14 mvahora
mvahora
  • 214 posts
Posted 04 December 2021 - 01:07 AM
Noted, ill do the suggested connections. thanks for that. Will test again today and hopefully come back with some positive results.
#15 mvahora
mvahora
  • 214 posts
Posted 04 December 2021 - 09:55 AM
So i connected the spark plug body to earth, connected the coil mounting bracket to earth. And dizzy to earth.
Same issue as before. Everything has 12v. No spark.
Im pretty sure the lumenition electronic magnetronic ignition is dead. I remmember about 15 years ago i took my mini to a mechanic who disconnected it to do some work. When he went back to reconnect it he plugged the positive into the negative on the coil by mistake because the symbols were hard to read on the coil; and he was just lazy to bend over and check properly. Luckily i was there at the time and remember hearing a bang and smoke coming from the dizzy area. I remember the car not starting after that so I had to replace the dizzy to get it going again
That time I didn't really know much and was very new to minis. Took the "specialists" word and replaced the dizzy.
Edited by mvahora, 04 December 2021 - 10:49 AM.
