Mk1 850 Restoration/s!
8 replies to this topic
#1 markomate
markomate
    Just On Tickover
  • 8 posts
Posted 28 November 2021 - 07:29 PM
Hi
I've posted a couple of pics in the Introduce yourself section, but Im now starting work on one of the two MK1's
I've acquired so I thought Id start a thread here.
Short background, I've got two MK1's 850's, LHD, bought from Finland. Im in Estonia.
One of them has been dismantled but appears complete apart from the rear subframe (no surprise there!)
The other is complete, apart from a missing voltage regulator.
Both cars could be classed a shed finds and have been dry stored for a long time, possibly 30 years.
Neither has been restored.
Starting on the stripped one first as its in pretty good condition, its never been welded/restored and appears to have a genuine miles 37000 miles.
The sills only have some small holes on the top but one of the rear sections is bad, one wing is needed along with small sections of the front floors, and the battery box. The A panels are solid!
Plan is to do a full restoration back to factory spec, no mods. I've ordered a Heritage Certificate, they have already given me the engine number to confirm it matches the VIN.
Id like to keep the wet suspension if possible.
I removed the head today just to check the bores, no ridges at all on the bores and the pistons are standard incl the factory matching letters on the pistons and block deck.
Ideally I don't want to re-bore it but Im replacing the pistons anyway so I may do it.
I suspect the crank will also be ok.
One of the doors is perfect, the other has a rusty bottom, I may repair it or "borrow" a door from the complete one which has two good doors.
Im media blasting the shell etc soon, so Ill post some "after" pics.
I can source new parts from Finland or the UK. Repair panels are made in Finland.
Couldn't help but do a clean up of the brake balance valve and the carb! Looks nice, only needed a needle valve!
Pics below
Edited by markomate, 28 November 2021 - 08:08 PM.
#2 Viktor
Viktor
  • 658 posts
Posted 28 November 2021 - 07:42 PM
Welcome to the forum and best of luck with your projects. Glad to hear that you are restoring them back to factory condition. I will be following.
Cheers.
Victor.
#3 edp
edp
  • 28 posts
Posted 28 November 2021 - 07:46 PM
Looking forward to seeing progress!
#4 mab01uk
mab01uk
  • 13,021 posts
Posted 28 November 2021 - 10:47 PM
You might also find the Mk1 Forum helpful:-
http://mk1-forum.net/index.php
Also the Mk1 Performance website for history info:-
https://mk1-performa...k/mk1_index.htm
#5 Austin65
Austin65
  • 10 posts
Posted 29 November 2021 - 05:46 AM
Thank you for sharing.  I have '65 850 that was mostly restored, so it is nice to see some original pictures if I need to make sure I have all the right pieces.
#6 markomate
markomate
    Just On Tickover
  • 8 posts
Posted 29 November 2021 - 09:22 AM
Let me know if you want some pics of the one that's still complete, Im calling it "Mini 2".
#7 johnR
johnR
  • 2,322 posts
Posted 30 November 2021 - 08:56 AM
Restoring two will keep you busy for quite a while!
#8 markomate
markomate
    Just On Tickover
  • 8 posts
Posted 30 November 2021 - 10:34 AM
Yes, going to be a busy Winter here!
Just sorting setting up a "tent" to do the media blasting in.
Im hiring a professional kit including a large towed compressor!
#9 markomate
markomate
    Just On Tickover
  • 8 posts
Posted 11 December 2021 - 04:25 PM
Quick question about interior trim!
I've now got the heritage certificate for one of the cars, the stripped one.
Good news is all the numbers match including the body number, with the original plate welded to the drivers side foot well.
It also says it was fitted with a "Boosted heater", destination country was Finland of course!
The certificate says body colour Tartan Red, Interior Tartan.
The carpets and interior panels are red but the seats are black
The other Mini has an all red "tartan" interior to match the tartan paint. Including red seats.
Does anyone know if black seats were fitted to cars with red interiors?
Mark
