Love to see a photo of this!
What I usually do is to mount a rear exhaust 'cotton-reel' fitting under the bonnet bolted through the bulkhead or inner wing. I connect the main battery feed to the threaded stub, which is insulated by the rubber in the mounting. That gives a good power source to feed to additional fuse boxes without attaching to the starter solenoid. I put a rubber cap onto the live stub and when i need to charge the battery I just have to open the bonnet and take off the rubber cap.
The advantage is that crimp-on ring terminals can be used to take power to fuse boxes and the cable lengths are relatively short and look tidy.
