Any suggestions as to what product is best to chemically strip some alloy wheels back to bare metal?
Best Answer whistler , 25 October 2021 - 09:50 AM
StarChem has been recommended to me .. but it's nasty stuff on human skin, etc.
Ordered some of this last night. I'll give it a try. The wheels have been rattle can sprayed by the looks of it. Nitromors has shifted some of it in patches but I'll use the Starchem gloop when it arrives. Might have to finish it off with a soda blast.
Go to the full postPosted 24 October 2021 - 11:40 AM
Posted 24 October 2021 - 01:12 PM
Posted 24 October 2021 - 02:42 PM
Paint stripper or acid dipping as any abrasive will damage the wheels
Any particular brand of paint stripper. I used Nitromors a couple of years ago to strip a clubman roof. Couldn't paint it afterwards as paint reacted with whatever was in the metal. Had to have it wrapped finally so not a fan of Nitromors.
Posted 24 October 2021 - 03:35 PM
Posted 24 October 2021 - 09:54 PM
Any particular brand of paint stripper. I used Nitromors a couple of years ago to strip a clubman roof. Couldn't paint it afterwards as paint reacted with whatever was in the metal. Had to have it wrapped finally so not a fan of Nitromors.Paint stripper or acid dipping as any abrasive will damage the wheels
Posted 25 October 2021 - 06:56 AM
Posted 25 October 2021 - 07:01 AM
It may be difficult to obtain a paint stripping product that's effective on factory coated wheels. The ban on methylene chloride (dichloromethane, DCM) for consumer use neutered these products. As far as I know, there is no substitute with near the same effectiveness.
Probably your best bet is to see if a professional wheel refinisher will strip them for you.
Another option is to locate a professional media blasting outfit who has the right type of blast media to strip the wheel coatings.
If the wheels are going to be painted or powder coated you have a lot of options for blasting - just make sure none of them use ferric-based blast media. If you have polished surface wheels, then the options are much more limited - some say soda or glass beads will work. Vapor blasting would be the safest choice but that takes specialty equipment not every blasting outfit has (most probably don't.)
Should you be determined to do this at home, then I don't know of any good options (i.e. ones that won't take a ton of effort beyond what it used to take 15 years ago.) I'd try to get some contacts in the industrial world, and see if you can still pick up a DCM-based paint stripper from them.
Dave
Posted 25 October 2021 - 07:26 AM
I agree, Nitromoors is crap. I bought an industrial strength stripper from ebay. Not cheap, but works ok .
Posted 25 October 2021 - 09:19 AM
Posted 25 October 2021 - 09:50 AM Best Answer
Posted 25 October 2021 - 04:28 PM
StarChem is excellent. Just take some precautions , gloves and glasses, when using it.
Posted 29 October 2021 - 08:19 PM
Posted 30 October 2021 - 10:08 AM
My Starchem has arrived so I'll have a go in a week or so when I have more time.
Posted 30 October 2021 - 10:27 AM
I had a word with the local blasters. They did me £15 a wheel, cash in hand. Given that they were Mistral Minilites it would have taken me days to strip them otherwise. Best £75 I've spent on farming a job out.
