How To Get Instrument Cluster Out Of '93 Cooper Dash?
10 replies to this topic
#1 bergxu
bergxu
  • 13 posts
Posted 21 October 2021 - 02:33 PM
Hi lads,
Fuel nor temp gauge are working. The car is new to me and I don't want to drive it yet until I have both of those operational. Car is a '93 SPi. Seems that from my reading the Nippon gauge is likely faulty, so I'd like to remove the cluster and send it out for repair (I'm in the US but we've got a handful of good instrument shops I've used here before). Can anyone guide me on removal of the cluster? The car has the wood fascia so don't want to go messing about till I've got instruction on hand!
Cheers,
Aaron
Edited by bergxu, 21 October 2021 - 02:34 PM.
#2 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 21 October 2021 - 03:56 PM
The cluster will be screwed into the back of the dashboard and you'll need to remove it to separate the two. Three nuts to undo to accomplish this, remove the radio as there's one behind there that attaches to the bottom dash rail there's also one under the dash on the drivers side tucked in tight behind the fuse box likewise there's one in the same location on the passenger side (same regardless of LHD or RHD). Wiggle the dash out once you've pushed the bolts clear, there's also a serrated bracket that pushes against a lip holding the top of the dash in place. Again just give the dash a tilt and a wiggle and it should come out, there's nothing to undo as such.
Take out the speedo cable unplug everything and job done.
Edited by Blake71, 21 October 2021 - 03:57 PM.
#3 Tornado99
Tornado99
  • 750 posts
Posted 21 October 2021 - 06:05 PM
Since both fuel and temp guages are out, suspect the voltage regulator (10v output) is dead as it powers only these two units. There is a modern electronic solid state version available (Minispares but likley US sellers). Original is electro-mechanical so can/do eventually fail. There is also an old thread somewhere describing how to solder in a 10volt regulator (available from most electronics parts suppliers or on line) to the circuit panel yourself.
#4 bergxu
bergxu
  • 13 posts
Posted 21 October 2021 - 08:10 PM
Thanks gents, I was under the impression that the ‘93 didn’t have an external voltage regulator and that it was integral to the Nippon Seiki instruments? Am I wrong?
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 21 October 2021 - 08:12 PM
Here, this will help. The instructions are for the MPI but it should be similar. Checkout page 361 of the PDF.
https://www.theminif...attach_id=68239
By the way, this is the manual for the SPI. You will need it.  :whistling:
 http://miniscene-unt...anual_92-96.pdf
#6 Tornado99
Tornado99
  • 750 posts
Posted 21 October 2021 - 09:34 PM
Thread I was thinking of, specifically replacing the injection model, Nippon instrument voltage reg:
https://www.theminif...tage-regulator/
#7 bergxu
bergxu
  • 13 posts
Posted 22 October 2021 - 03:08 AM
Many thanks gents! I’ll get on this over the weekend!!!
#8 bergxu
bergxu
  • 13 posts
Posted 22 October 2021 - 12:49 PM
Having a read of the manual, it wants you to remove the steering column in order to pull the wooden fascia. Is this really necessary?
#9 Quinlan minor
Quinlan minor
  • 1,170 posts
  • Local Club: LSMOC
Posted 22 October 2021 - 12:58 PM
Not if you're careful.
#10 bergxu
bergxu
  • 13 posts
Posted 23 October 2021 - 12:00 PM
Cheers thanks!
#11 MatthewsDad
MatthewsDad
  • 812 posts
Posted 23 October 2021 - 05:49 PM
It is just the three fixtures as described above. No need to start dismantling anything else.
