Electronic Mini Speedometer - Ignition Light Wiring Question
Best Answer jedduh01 , 14 October 2021 - 07:20 PM
I can't help with any more info than above on wiring, but would like to know if the speedo was a recent purchase, as these have. Been listed as out of stock on MS for over a year now.
Few Updates :+ Successes
Caerbont replied.... It is nearly as simple as mentioned above.
    Gauge has Brown / Yellow wire =  Ignition lamp has Brown Yellow wire too = Connect those two. The white other side of the lamp is unused.(or internal to the gauge)
  That connected and worked.
This Was purchased 2 weeks ago from Minispares  + 1 week for Shipment and transport to the USA.
 Was in Stock = Looking now = Appears back order again!   Did I just Luck out for this one?~  This actually was the 130 MPH Variant   Nice to see other options out there with the simpler 90 MPH = which I would actually have preferred.
Now , upon first use .. and attempting to calibrate my speed signal to the gauge  .. I was having some Strange readings + Gauge jumping around and when calibrating the engine was running it was making up its own' signal.
 Remove sensor from trans = test with engine off = 1 rotation = gauge registers 1 rotation.
      Engine running = errant signals sent.
 Another TMF Member sent an idea... Resistor vs NON resistor Spark plugs.
          I changed the car to Resistor plugs ( to get rid of the extra 'electrical' NOISE) and  so far appears to have stopped the errant signal.
Video of sitiuation included.
https://photos.app.g...2hRgmhVu24w5c67
Doing final re assembly now = then off for a test drive + calibration test.
Thank you everyone for the guidance... NEW fancy speedo appears to be nice, bit of a headache.
Go to the full post
15 replies to this topic
#16 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 21 October 2021 - 07:00 PM
Just adding a couple of notes for future reference.
I got this from Digital Speedos awhile back when I bought a replacement sensor:
I checked the records and you did purchase a KOSO unit previously, the reason the KOSO probably failed is because its a five volt sender and unless you connect to the 5 volt output (pink wire) on the gauge it can fail.
The reason we swapped over to the Daytona is because it works on both 5 volts and 12 volts so it takes out any chance of using the wrong power input. I shall exchange it for a Daytona for you.
Best Wishes - Jon
I connected it to 5 volts, but still had a failure at some point.
The picture shows what happens to the mechanical end of the sensor after 5000 miles plus. The shrink tubing deteriorates with time.
Edited by tmsmini, 21 October 2021 - 07:01 PM.
