Electronic Mini Speedometer - Ignition Light Wiring Question
Best Answer jedduh01 , 14 October 2021 - 07:20 PM
I can't help with any more info than above on wiring, but would like to know if the speedo was a recent purchase, as these have. Been listed as out of stock on MS for over a year now.
Few Updates :+ Successes
Caerbont replied.... It is nearly as simple as mentioned above.
    Gauge has Brown / Yellow wire =  Ignition lamp has Brown Yellow wire too = Connect those two. The white other side of the lamp is unused.(or internal to the gauge)
  That connected and worked.
This Was purchased 2 weeks ago from Minispares  + 1 week for Shipment and transport to the USA.
 Was in Stock = Looking now = Appears back order again!   Did I just Luck out for this one?~  This actually was the 130 MPH Variant   Nice to see other options out there with the simpler 90 MPH = which I would actually have preferred.
Now , upon first use .. and attempting to calibrate my speed signal to the gauge  .. I was having some Strange readings + Gauge jumping around and when calibrating the engine was running it was making up its own' signal.
 Remove sensor from trans = test with engine off = 1 rotation = gauge registers 1 rotation.
      Engine running = errant signals sent.
 Another TMF Member sent an idea... Resistor vs NON resistor Spark plugs.
          I changed the car to Resistor plugs ( to get rid of the extra 'electrical' NOISE) and  so far appears to have stopped the errant signal.
Video of sitiuation included.
https://photos.app.g...2hRgmhVu24w5c67
Doing final re assembly now = then off for a test drive + calibration test.
Thank you everyone for the guidance... NEW fancy speedo appears to be nice, bit of a headache.
Go to the full post
15 replies to this topic
#1 jedduh01
jedduh01
  • 45 posts
  • Local Club: CMU Classic Mini's United
Posted 13 October 2021 - 02:56 AM
Greetings All
Purchased the "Smiths' Classic mini Speedo Electronic Speedometer - Purchased from Mini Spares  - Is made by Caerbont Automotive Instruments.
   I did send inquiry to Carerbont. ... no reply yet.
 Wondering if any one can guide me for the proper wiring of the RED Ignition Lamp.
I have all functions connected and working Except the ignition Light.
________________________________________________________________________________________________
Per their instructions :  {Brown / Yellow wire  -  Battery Warning Light - Connect to ground to Illuminate}
I for some reason can not imagine how this works / wires up
     The car has a bulb + Socket as original.
  The one Brown/ yellow wire goes to one side of the bulb.. the other side of the bulb is a White wire. that is always Hot when the ignition is on.
Has any one wired this speedo to the Red Ignition lamp?
 Can any one explain the wiring to this gauge better to me?
Any guidance or assitance appreciated
 Many Thanks
Justin Handy
NC, USA
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 13 October 2021 - 07:01 AM
The white wire is ignition as you’ve said. The brown/yellow goes to the alternator where it is effectively earthed when the engine isn’t running. So with ignition on the lamp illuminates.
Then once the engine is running, and the alternator is producing voltage, the brown/yellow also becomes ‘hot’ so the lamp has 12v on both sides and hence goes out.
Don't be tempted to replace the lamp with an LED either, the alternator needs to ‘see’ the 12v ignition voltage initially in order to work. An LED (without some additional circuitry) doesn’t allow this to happen.
#3 Tornado99
Tornado99
  • 750 posts
Posted 13 October 2021 - 03:44 PM
#4 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 13 October 2021 - 04:49 PM
This one?
https://www.europasp...ace-90-mph.html
#5 PoolGuy
PoolGuy
  • 848 posts
Posted 13 October 2021 - 04:50 PM
I bought mine from here https://www.digital-...peedometer-p327
#6 Spider
  • 14,836 posts
Posted 13 October 2021 - 08:38 PM
,,,,, I did send inquiry to Carerbont. ... no reply yet.
Keep 'nagging' them but do it in a polite way, forward on your first email and just write something like " Hi, just needing a reply on this, thanks " with your original emails(s) in a string. They are slow, but will respond. Usually once you have their attention, they are good. If you don't get a reply in say 2 - 3 weeks, send me a PM.
That's quite correct of a stand along LED, however these Speedos do have a shunt in them to ensure correct Alternator excitation for those that need a shunt.
#7 Pairaminis
Pairaminis
  • 194 posts
Posted 14 October 2021 - 12:14 PM
What triggers the electronic speedometer to calculate speed?
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 14 October 2021 - 12:25 PM
A speed sensor - either screwed into the gearbox or on the cable somewhere.  I think you can also use a hall effect sensor and suitable trigger
#9 Ethel
  • 25,919 posts
Posted 14 October 2021 - 01:11 PM
I saw a link somewhere saying gps, which doesn't sound right and wouldn't be legal.
There's a piccy of the rear on Minimania that shows just a molex multipin connector. Seems likely it is a LED, but hopefully has the circuitry to wire in as a direct replacement. If you have a couple of left over wiring tails, preferably 1 white, the other brown/yellow, I'd be inclined to give it a go.
You could hook 'em up to 12v & reverse the polarity to see if the ign light shows both times.
Re reading the original post it does have brown/yellow & presumably makes the "white" connection internally. I expect it'll work as the original light did under normal conditions. It might not show overcharge/low battery voltage though.
#10 stoneface
stoneface
  • 367 posts
Posted 14 October 2021 - 02:20 PM
I don't have a Smiths gauge but mine uses magnets on the pot joint and a sensor
Attached File  Speedo Magnetic Pickup.jpg   84.42K   4 downloads
#11 PoolGuy
PoolGuy
  • 848 posts
Posted 14 October 2021 - 04:50 PM
All the warning lights and illumination in the Smiths electronic speedo are led, the unit is sealed.
#12 jedduh01
jedduh01
  • 45 posts
Posted 14 October 2021 - 07:20 PM   Best Answer
Edited by jedduh01, 14 October 2021 - 07:30 PM.
#13 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 14 October 2021 - 11:20 PM
Glad it was the plugs. I do like the speedo, it is nice to be somewhat accurate.
Sure had me freaked out for awhile. Sending a gauge to the UK for repair from the US has not worked out well in the past for me.
Terry
#14 Spider
  • 14,836 posts
Posted 14 October 2021 - 11:55 PM
The Speed sensors Mini Spares currently have for these are not suitable. The ones they used to have were OK.
As you find, these are only 1 pulse per rev. These Speedos need a minimum of 6 in order to register speeds below about 25 - 30 mph.
These will work properly;-
https://www.digital-...oso-models-p417
#15 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 15 October 2021 - 12:50 AM
I have certainly had issues with both Daytona and Koso sensors. The other problem is that the "spindle" is not exactly the same as the Mini cable for either brand.
I am not sure who modifies them for use in a Mini, but some I got had a metal sleeve that needed adjustment to work and now they just come covered in shrink tube which seems to wear.
