Crank Trigger Offset Jdm Spi With Mpi Flywheel
6 replies to this topic
#1 Wazzah
Wazzah
  • 142 posts
Posted 03 October 2021 - 03:51 AM
I am after information regarding the MPI flywheel, its missing teeth and the crank angle sensor offset.
I am currently fitting an aftermarket ecu to my 99 JDM SPI Mini.
This year model uses an MPI block with the 36-4 flywheel trigger.
The ecu software has the MGF trigger system which I believe is the correct 36-4.
That MGF trigger is set at a 70 degree offset as a default.
It simply wont start on this setting.
It will fire but the ignition event is way too early as the engine struggles to turn over.
I was using static ignition advance of 10 degrees BTDC.
Retarding advance to 6 degrees didn't help.
Adjusting this offset seems to be the answer given this is the only other variable.
I believe the 36-4 pattern has it's first missing tooth at 30 degrees and it wont fire at a 30 degree trigger offset.
Increasing the offset gradually hasn't helped.
I have a MEMS document (attached) that states the first missing tooth is at 80 degrees and that the crank sensor itself is 55 degrees offset from top dead centre.
I can get it to run at a fast idle at of 1200 rpm with an 85 degree offset in the software but am worried about knock.
The ECU supplier (Haltech) has no information that assists me.
Do any members have better information that I can get my head around?
#2 genpop
genpop
  • 508 posts
Posted 03 October 2021 - 06:33 AM
Hi Wazzah,
accordig to your pdf, the CMP has to be on the right position too.
#3 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 03 October 2021 - 07:02 AM
Wazzah, speak to Haltech Australia. They still have the map from Moog's car which was the same base engine as yours.
Are you using a light gun to set the timing?
Edited by Steve220, 03 October 2021 - 07:04 AM.
#4 Bobbins
Bobbins
  • 1,486 posts
Posted 03 October 2021 - 07:32 AM
A '99 JDM is fundamentally an MPi bottom end and flywheel with the older SPi injection, ignition timing is therefore the same as for an MPi, it is only the injector firing that needs to be different, although I'm sure you're aware of this!
However, although the MGF flywheel has a 36-4 flywheel pattern it's a K-Series. Are you sure missing teeth the pattern is the same for both? Even if you allow for a different offset for the location of the crank position sensor a variation in the pattern of the Mpi flywheel and the pattern the ecu is expecting to read would cause major issues. Definitely worth double checking.
#5 FlyingScot
FlyingScot
  • 2,664 posts
Posted 03 October 2021 - 03:58 PM
Think this might help… https://www.theminif...i-ignition-out/
Also I’m presuming it’s the same clutch as before…
FS
#6 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 30 August 2023 - 12:04 PM
Just to bring this back up after a similar issue - Remember the pre-set for the 36-4 K series flywheel is based on just that - the K series! The A series MPi has the same flywheel, however the sensor is in a different location, and therefore the offset is very different. Each ecu manufacturer may also have a different placement on the flywheel where it classes TDC, so the only true way to find it is with a strobe and changing the offset 10 degrees at a time to bring it into sight, then adjust it a few degrees at a time to bring it into true.
#7 1994JDM_mini
1994JDM_mini
    Starting My Mini Up
  • 3 posts
Posted 02 October 2024 - 03:19 AM
Wazzah
did you get this sorted out? if not I would recommend a few changes to your Haltech ECU.
Synchronize/Set Ignition timing: under “Ignition Tuning”  set Lock Mode to “Always” under “ Firing Angle, set it to 12. Now go to “Engine Configuration”, “Trigger System”. This is where you increase or decrease the value until the timing light also is set to 12. It says “TDC Angle (0-719.9 degrees) This will vary for every vehicle. You can increase or decrease the values as needed ensure your timing is set for the desired value, this just synchronized the physical timing belt to the ECU. Once you have synchronized your timing. Go back and remove the “Always” under “Ignition Tuning” Ideal TDC is 8-10 degrees BTDC at 750-1000 RPM’s. The reason I set mine to 12 is because its the 4th marker on my timing makings, it goes from top to bottom 0,4,8,12,16,20. check your manual and engine for ideal timing settings. Wazzah, it also helps to disable the injectors while you are synchronizing your timing.
I am using a 36-1 trigger system on my SPI, it does come with the k trigger but I wanted to go with a hall effect sensor for reliability. I hope this helps. I was trying to upload some screen shots of the ECU setting but don't know how.
