Best Answer postve , 19 October 2021 - 03:02 PM
Conclusion - thx Steve and others - well as mentioned above last owner installed two of the same brake disk calipers hence the reason why one nipple is at bottom and simply cannot flip around. So, what did I do, I removed the caliper pictured above, flipped it right side up and bleed the thing in my hand with trusty assistant and viola, bubbles came out and problem solved. Will leave as is for now as calipers are good just same - RH - on both sides.
thx again for all the help..
Go to the full post
Posted 27 September 2021 - 11:43 PM
What the heck are we doing wrong!!
1293 engine - 1978
Bench bleeding picture for reference
Posted 28 September 2021 - 01:11 AM
What I have read on these forums is if you apply pressure from pedal for bleeding rears it can trigger the pressure reg device such that no or not much pressure reaches rear cylinders, so not enough fluid gets through the reg to bleed it fully.
A gravity bleed, with no pressure from pedal or a vacuum bleeder at rear cylinder means the reg stays fully open letting max fluid through to get air out.
Posted 28 September 2021 - 02:35 AM
Have heard the rear brake pressure regulator can be a problem to bleed properely. Has a vacuum bleeder been used?
So basically open the rear bleeder nipples and let fluid drip out ?
Posted 28 September 2021 - 02:53 PM
Ive still got an initially soft pedal after replacing some worn out parts.
To get around the pressure regulator I opened all the bleed nipples and got pumping until fluid was coming out of all the nipples at once. Then I went around each one conventionally. Still not perfect though.
Posted 28 September 2021 - 04:02 PM
I`m guessing you are not using a http://www.minispare...|Back to search that would originally been fitted to your car unless it was late registered.
If not try opening the rear bleed nipples on at a time then get an assistant to quickly press the brake pedal to the floor and hold it there until you do the nipple up.
This way the http://www.minispare...|Back to search can`t close the circuit off.
It`s also quite possible that the brand new master cylinder needs a quick strip and clean as occasionally the small washer seen here http://www.minispare...|Back to search
can stick to the back of the seal and that stops the brake fluid being pulled through to replace the space.
So basically that`s the non return valve so if it`s stuck to the back of the seal the brake master acts more like a clutch cylinder and the pistons are pulled back when you release the pedal.
I would try that as a last resort and a gravity bleed followed by a couple of stabs will hopefully do the trick.
Also check your flexi hoses if you are using them as they can collapse and or swell inside and give similar issues.
Posted 28 September 2021 - 04:28 PM
So basically open the rear bleeder nipples and let fluid drip out ?Have heard the rear brake pressure regulator can be a problem to bleed properely. Has a vacuum bleeder been used?
Yes, that's the way it works. Use a bit of hose on nipple to direct fluid drips to catch bottle. Keep reservoir topped up. Close once no more. Bubbles or dirty fluid. Can open more than one circuit at same time. Give them 15-25 minutes per wheel minimum for complete fluid change. Works great for me when doing yearly fluid changes.
Heres a video describing method and why it is better from old systems:
https://youtu.be/5Mkj2fRmTws
Posted 28 September 2021 - 05:37 PM
I've never used a pressure or vacuum bleeder, always the two man method.
I generally loosen the nipple before pumping the pedal, give it 10 slow pumps, then tighten with the nipple down.
Bleed order on a RHD car
Passenger rear
Drivers rear
Passenger front
Drivers front
Hope this helps
Cal
Posted 28 September 2021 - 06:31 PM
Never had to bench bleed a single line MC ever they are so simple.
I would say the you need to set the rear brakes correctly.
Posted 28 September 2021 - 07:12 PM
[attachment=214701:brake.jpg]
Sounds like a good plan and I did a gravity bleed and all worked well yet issue persisted. Yes, to your question above on the limiter, and see attached photo of what I currently have or at least last guy had in car. I have two brand new MC, swapped and same issue - lol - selling one soon.thoughts on my image - maybe disconnect and check that?
Posted 28 September 2021 - 07:14 PM
Good reco Nick and adjusted and set as per spec - should barely move after adjustment - issue persists. Agree with bench bleed, I always do this type in car but was desperate so pulled out and bench bleed anyways
Posted 28 September 2021 - 07:16 PM
I've never had an issue bleeding brakes, make sure any brake calipers (if fitted) have the bleed nipples to the top, the same applies to a brake cylinder.
Passenger rear
Drivers rear
Passenger front
Drivers front
Hope this helps
Cal
Agreed and did that Cal, and interestingly enough one of the nipples - 7.5 discs at front - last owner had mechanic install incorrectly - at bottom, but, it still should work as it has for the last 6 years - not sure that is my issue but one all the same.
Posted 28 September 2021 - 07:18 PM
Thx Mike, mine is brutal - takes three pumps and no way in hell would I drive this fast behind other cars and certainly not on the highway. All this is compounded with my new Super charger - which runs amazing by the way - so brakes being spot on is absolutely critical for my life's sack.
Posted 28 September 2021 - 07:19 PM
Good point and did gravity bleed today - which was spot on - issue persists
Posted 28 September 2021 - 07:24 PM
thx Torn - followed to the letter, fluid looked great, issue persists - I am thinking - absx2 - reco. on flex lines could be a potential issue...not sure how I can test these other than replace - cheap anyways
Edited by postve, 28 September 2021 - 07:59 PM.
Posted 28 September 2021 - 08:07 PM
Just confirmed today existing brake hoses are @20 years old - waiting for new ones to arrive tomorrow.
Edited by postve, 29 September 2021 - 10:57 AM.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
