Wing Aerial Nut
10 replies to this topic
#1 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 07 September 2021 - 03:32 AM
Hi everybody, a quick question:
Is there any special tool to use when fastening the original wing-mounted aerial? Or do you just fasten it by hand?
Thank you!
#2 MikeRotherham
MikeRotherham
  • 973 posts
Posted 07 September 2021 - 06:38 AM
Can you show us what the nut looks like?
#3 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 07 September 2021 - 09:04 AM
It’s the OEM Mini aerial…
#4 sonscar
sonscar
  • 2,921 posts
Posted 07 September 2021 - 10:59 AM
Looks like it has already been drifted round with a screwdriver.Cut a groove to fit round the mast in some 2mm? steel and bend the end prongs over at 90degrees to locate in the slots?Steve..
#5 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 07 September 2021 - 11:31 AM
Yeah, that was me trying to fasten the nut with a screwdriver end over the years... That's why I was wondering if there's a special tool to fasten it... 😅
#6 MikeRotherham
MikeRotherham
  • 973 posts
Posted 07 September 2021 - 11:55 AM
The tool looks like this:
Edited by MikeRotherham, 07 September 2021 - 11:56 AM.
#7 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 07 September 2021 - 12:37 PM
That's awesome! Thank you...
Do you know what it's called so I can look it up on the Bay of E or similar...?
#8 MikeRotherham
MikeRotherham
  • 973 posts
Posted 07 September 2021 - 12:42 PM
It's something that came with a new Unipart brand aerial.
They were fitted as OEM equipment on Minis and Metros
#9 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 07 September 2021 - 12:45 PM
Ah, okay... seems it will be kinda hard to get one then, or like sonscar (Steve) said, I will need to fashion one myself...
Thank you for the pic!
#10 Red Riley
Red Riley
  • 158 posts
  • Local Club: British Car Club of Charleston
Posted 07 September 2021 - 06:09 PM
Try an angle grinder spanner tool. You might get lucky, or at least it would be easy to modify into what you need.
Edited by Red Riley, 07 September 2021 - 06:10 PM.
#11 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 08 September 2021 - 05:30 AM
That's also a great idea! I'm currently using a snap ring pliers, but will look into your idea. Thanks!
