Green Wire To Stereo (1990 Mainstream Cooper) Has No Power - What To Check?
1 reply to this topic
#1 roblightbody
roblightbody
  • 448 posts
Posted 02 September 2021 - 05:20 PM
Hi,
The green wire to the radio harness on my 1990 Cooper is showing no power (with multimeter).  Purple wire (permanent i presume) is OK.  I believe from reading here that the green wire is the switched ignition feed for the car, so would be the main power for the radio.  I had used this fine previously, but it has conked out.  I can't see any sign of a fuse for this wire?
Any help appreciated as to what to check next.
Thanks,
- Rob
#2 roblightbody
roblightbody
  • 448 posts
Posted 02 September 2021 - 05:43 PM
I posted too quickly... Just found an in line fuse under the steering wheel (looks original) which had blown.
