Fuel Pipe Help
52 replies to this topic
#1 mrmeds
mrmeds
  • 250 posts
Posted 29 August 2021 - 04:14 PM
it looks like E10 fuel has eaten the rubber on my braided fuel pipe of my twin 1 1/4 SU carbs, fitted new 18 months ago as part of JCG conversion.
Car is now leaking petrol over the manifold !.
Need to buy replacement, does anyone know what diameter I need ?
It measures 1/2 inch externally- but is the measurement the internal bore ?
thanks
Edited by Spider, 01 September 2021 - 07:21 PM.
Language please !
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 29 August 2021 - 04:20 PM
I used 1/4 inch ID on my HS4s (7mm is close but slightly too loose IMO so if the clamp fails or stretches then fuel leaks).
If the fuel hose is tight to go on heat it up in a cup of hot water.
Hope this helps
#3 mrmeds
mrmeds
  • 250 posts
Posted 29 August 2021 - 04:41 PM
Hope this helps
thanks
#4 richmondclassicsnorthwales
  • 942 posts
Posted 29 August 2021 - 06:20 PM
6mm is what I use with 1/4 in fuel hard line and 10 -12 mm fuel clips
I use Cupro lines or Copper , and with these I put a slight flare to make the hose "Catch" better
Just a personal choice. I also try to keep the rubber lines shorter rather than longer, and avoid bends, so the E10 petrol has less to attack
Straighter the rubber, the better.
Additionally, rubber is not as good as it used to be, from the day it is made, it starts deteriorating
#5 sonscar
sonscar
  • 2,997 posts
Posted 29 August 2021 - 06:24 PM
I would not recommend braided fuel lines after a similar failure,you cannot see what is happening until it fails,Steve.
#6 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 30 August 2021 - 04:28 PM
Don't think anywhere has E10 in UK yet ... but the ethanol in E5 was probably a factor
#7 nicklouse
  • 18,583 posts
Posted 30 August 2021 - 04:56 PM
It is appearing but E5 ,as you say, will do the same.
#8 mrmeds
mrmeds
  • 250 posts
Posted 30 August 2021 - 07:18 PM
my bad- E5-  but going to use premium from now on
#9 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 31 August 2021 - 01:31 PM
Some (most!) have ethanol in that too .. up to E5 (5%)
#10 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 31 August 2021 - 06:21 PM
All UK pump petrols have ethanol.
Replace hose with R14.
#11 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 01 September 2021 - 10:41 AM
Apparently not Esso Supreme99+ .. although is may say 5% on the pump they claim is contains zero ethanol .. the law is UP TO 5% or 10% apparently.
#12 Deeppockets
Deeppockets
  • 100 posts
Posted 01 September 2021 - 11:10 AM
Gates has a range of ethanol-proof fuel hose to SAE 30R14T
Carb:
4219BG Barricade™ Carbureted Engines Fuel Hose | Gates Corporation
Fuel Injection:
4219BF Barricade® GreenShield® Fuel Hose | Gates Corporation
Moss list a Gate product line but not fully clear which line it is
Ethanol Proof Fuel Hose by Gates (moss-europe.co.uk)
Edited by Deeppockets, 01 September 2021 - 11:17 AM.
#13 humph
humph
    How bad can it Be?
  • 1,096 posts
Posted 01 September 2021 - 12:10 PM
Yes and no, Esso Supreme does contain ethanol in certain parts of the country. See the vague and pretty unhelpful answer to their faq below.
https://www.esso.co....n-gb/fuels-faqs
Esso Synergy Supreme+ 99 contains zero ethanol, except (for logistics reasons) sites supplied from Scotland, North Wales, North England and Cornwall.
Edited by humph, 01 September 2021 - 12:10 PM.
#14 mrmeds
mrmeds
  • 250 posts
Posted 01 September 2021 - 05:52 PM
okay- replaced hose today with 1/4 inch braided  from minisport- went on easily - still leaked petrol- so tried a smaller clip at the end- still leaking ( fuel collecting on top of float chamber.
Am i missing something ?
Edited by Spider, 01 September 2021 - 07:23 PM.
Language please !
#15 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 01 September 2021 - 07:12 PM
Post a picture of how the hose is fitted now
