Voltage Stabilizer For 12V Devices
5 replies to this topic
#1 mvahora
mvahora
  • 212 posts
Posted 28 August 2021 - 10:11 AM
I've got a few items I'm installing in my mini such as a Heater, a stereo etc.
Do I need to provide these devices a stable 12V by running the feeds through a 12V stabilizer? How do I know if devices that are sold as 12V can deal with fluctuating voltages in a 14.4V car
I am aware that the smiths gauges need a 10V stable supply hence why they have a 10V stabilizer.
#2 Deeppockets
Deeppockets
  • 100 posts
Posted 28 August 2021 - 10:27 AM
Are you looking to provide 12v from a 12v+ supply or provide 12v on a wider range (i.e. while cranking)? The first can be achieved with a relatively simple linear regulator which drops the voltage and dumps voltage drop (x current) as heat, the second will need a DC-DC converter.
Current draw is also a key consideration, what is your planned max current/power?
#3 sonscar
sonscar
  • 2,996 posts
Posted 28 August 2021 - 11:32 AM
If they are designed for car fitting they will almost certainly be OK.If they fail they were probably no good to start with.Steve..
#4 nicklouse
  • 18,581 posts
Posted 28 August 2021 - 12:11 PM
They will be fine with the cars 12v system.
#5 Spider
  • 14,846 posts
Posted 28 August 2021 - 12:12 PM
The types of Accessories you've mentioned generally have their own stabaliser / regulator internally, if they need one to operate. While they have name plate voltage ratings of 12 or 13.8V, all that I know of are actually rated to 16 volts and some a bit higher.
In short, just connect them up.
Even the most latest range of Smith Gauges now don't need a stabaliser.
#6 Tornado99
Tornado99
  • 750 posts
Posted 28 August 2021 - 04:46 PM
Yes most all modern electric devices, certainly digital devices, use DC voltage regulators internally. No additional regulators after the cars alternator or battery are needed.
