Fuel Gauge Not Working
7 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 August 2021 - 02:08 PM
Hello
1993 L reg SPI Cooper, manual, RHD
I've either imagined it, or this has been raised and answered before (possibly a few times), but I can't find it through the search function.
Anyway....
Temp gauge works fine
Fuel gauge reads empty
The tank isn't empty
I've connected a jumper wire to the green / black wire on the sender unit and the -ve battery terminal
The gauge went up to full
I have a spare / new sender unit
Outside of the tank, in the boot, I then connected the green / black wire to the new sender unit
I connected the jumper wire to the black cable (not connected to the new sender unit) and the other end to the -ve battery terminal
I moved the float up and down
No change on the gauge
Now, I might have misunderstood this second test
I'm very good at misunderstanding
Do I need to connect both (green / black and all black) wires to the sender unit then also run the jumper wire from the black wire connection at the sender to the -ve battery terminal?
If I've performed the second test incorrectly then head back out to do it properly and the gauge still doesn't move (connected to a new sender), what then?
A fault in the black wire from boot to dashboard?
I have had the tank in and out of place a few times while I've been replacing the rear sub frame and rear shock absorber(s), so it's more than possible that I've damaged something in doing so.
Are there any other tests?
Regards
Elwyn
#2 Tornado99
Tornado99
  • 750 posts
Posted 15 August 2021 - 04:32 PM
Apparently it can happen that the internal float arm gets hung up against the tank and prevents movement. Can you use a coat hanger wire or similar to fish around and tell if the flaot arm is free to move?
Otherwise, might be the wiring not correct or damaged or the floats sensor is faulty. First step is to find out why your spare unit has a problem.
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 August 2021 - 05:12 PM
The spare is new
Out of the box / tube
I'd hoped that I would test the new one before fitting it and fit the gauge going up and down as I manually move the arm
But no
Nothing
Suggests a wiring problem?
#4 Quinlan minor
Quinlan minor
  • 1,172 posts
  • Local Club: LSMOC
Posted 15 August 2021 - 07:03 PM
I may be missing something, here, but just connect the new sender exactly as the original was connected. Lift the float to the upper position, turn on the ignition and it should indicate 'Full'. Move float lever to bottom position and the guge should go down to 'Empty'.
If it does that, fit it. Job done!
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 15 August 2021 - 07:27 PM
I've tried the new sender
Connected it to the green / black and black cables that go to the gauge from the boot
Lifted the float up
Lowered the float down
Nothing on the gauge
Just as there's nothing on the gauge with the wires connected to the old / current sender in the tank
It's possible that my old / current sender is faulty AND by chance, the brand new sender is also faulty, but I doubt it
Edited by Elwyn, 15 August 2021 - 07:28 PM.
#6 Tornado99
Tornado99
  • 750 posts
Posted 16 August 2021 - 05:35 PM
Put an Ohm meter on the new sender connections and try measuring change in reading as you move the float. If erratic or full open circuit or short circuit you have a bad sender. If it looks good then issue could be wiring to the dash has an issue.
#7 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 16 August 2021 - 07:33 PM
Very helpful
20 to 252 ohms
Increasing directly and smoothly in relation to the movement of the float
Black wire between the gauge and the sender is the fault, it seems
Unless I can find an obvious fault, would it be easier to run a new wire?
Coincidentally, the front seats and the carpet are out of the car
#8 Tornado99
Tornado99
  • 750 posts
Posted 20 August 2021 - 05:38 PM
Good the hear it is not the sender. Did you test both new and older units?
I don't know how the existing wiring is run to dash. If. The problem line is buried in some kind of conduit with other wires all wrapped up, then running a new wire would seem the easiest path. Be sure to fully secure it if running underside of car and using a conduit covering (like the plastic corrugated or flexible mesh type) can be a good idea.
Can you test the suspect wire with the Ohmeter attached at each end (you'll need a long bit of good wire to make the connections)? Might be all but the connection points are fine and you just need to scrape the connectors free of corrosion. A wire bristle brush and or White Vingear to soak the terminals in for twenty min usually do a great job.
