A bit more done had to order more panels will be glad when this one gets there
Edited by rick1962uk, 22 December 2021 - 04:32 PM.
Posted 22 December 2021 - 04:32 PM
Posted 30 December 2021 - 12:44 PM
thats the rear getting there
269931645_10159695865728781_4562241381340680580_n.jpg 39.24K
3 downloads
269889454_10159695865648781_6899862196724989372_n.jpg 26.1K
3 downloads
270050567_10159695865573781_7578526704306063855_n.jpg 35.09K
3 downloads
270031291_10159695865518781_7657725571061605929_n.jpg 57.28K
3 downloads
269979413_10159695865343781_5439071110414724416_n.jpg 32.93K
3 downloads
Edited by rick1962uk, 30 December 2021 - 12:49 PM.
Posted 31 December 2021 - 07:01 PM
now the end is near well sort off decided to puta full inner sill in i had floor panels with the sill on but was never happy with it was hard work cutting the new panels but realy worth it
Edited by rick1962uk, 31 December 2021 - 07:02 PM.
Posted 02 January 2022 - 02:45 PM
a bit of cut and shut so far the only panel that needed it
Edited by rick1962uk, 02 January 2022 - 02:45 PM.
Posted 03 January 2022 - 03:34 PM
thats one side just about there th other side just needs the 2 sill fitted then the boot almost there
Edited by rick1962uk, 03 January 2022 - 03:34 PM.
Posted 03 January 2022 - 06:01 PM
Posted 03 January 2022 - 09:02 PM
Your making really good progress with this!
Do you add more metal to the step repair where it curves towards B post?
no just the 3 parts was a mare getting them all to line up
Posted 04 June 2022 - 05:47 PM
Been away Racing for a few months but now back on the mini left hand sills fitted
Edited by rick1962uk, 04 June 2022 - 05:49 PM.
Posted 04 June 2022 - 05:49 PM
Then the Rear
Edited by rick1962uk, 04 June 2022 - 05:52 PM.
Posted 05 June 2022 - 07:23 PM
Then the Rear
Those panels at either side of the boot arent the best for repairing either side, theyre a cover panel really that is meant to go over the rear sub frame mounting. They dont provide any boot floor to go under the rear sub frame mount, which is needed as part of the reinforcement.
Not the best picture but you would be better with these (or some of these panels) from M machine.
Then you can cut what you need (or use the whole panel as you might need to)
The sub frame mount wants to go on top of that panel, not below.
I then did this to fit my rear valance.
Please dont take this as criticism as your doing great mate, just wanted to post a few pics in case you have the chance to pick up a few different panels which might work better for you
Posted 05 June 2022 - 07:50 PM
Posted 05 June 2022 - 08:41 PM
Posted 26 June 2022 - 11:30 AM
Left side took some sorting =but almost there i do have the closing pannels Back on the stand to get the underside finnished
Edited by rick1962uk, 26 June 2022 - 11:30 AM.
Posted 28 June 2022 - 05:51 PM
I've got the same 'repair' panels for my boot floor, I didn't realise that was what they were sending actually but we'll make it work
I've ordered replacement strengthening brackets both sides, gonna cut off the old brackets, tack the new ones to the repair panels with holes lined up / bolted in place to subframe, unbolt, take into the garage and fully seam weld them in underneath.. then fit the panels again, weld them in all round (obviously in place of the old metal though not just over the top)
later when the subframe is off, I''ll lose whatever is left of the 2 extra plates underneath and just replace them with nice new metal. as long as it's 3 layers total and all the panels look good and welded securely I can't see how it'll matter. plus it'll look a bit better being sort of smooth from floor into bracket. the part going over the wheel arch will also be properly seamwelded rather than just spot welded
it'll probably be stronger + tidier than it ever was coming out of the factory
Edited by stuart bowes, 28 June 2022 - 05:57 PM.
Posted 01 August 2022 - 06:40 PM
Quarter panels done now starting to look like a mini again
Edited by rick1962uk, 01 August 2022 - 06:40 PM.
1 members, 1 guests, 0 anonymous users
