No Dot On Crankshaft Sprocket
Best Answer postve , 12 August 2021 - 10:15 PM
The TDC of the crank (flywheel, pistons, crank pulley) happens twice per cam (and hence dizzy) revolution.
Google the 4 stroke cycle for some graphics that will show this and how it corresponds to the valve actions.
So - if you turn the crank one full revolution you will find that the rotor arm only moves 1/2 a revolution and then the rotor arm will point as you expect. When it does, check that the valves on cylinder 1 are closed. If they are - you're good.
Thx Graeme and everyone else, she fired right up no issues at all!! Go to the full post
23 replies to this topic
#1 postve
postve
  • 524 posts
Posted 11 August 2021 - 10:44 AM
Morning fellas,
Should I not see a mark on the smaller crankshaft sprocket in order to line up with DOT on the CAM sprocket. Just adding a new woodruff key and starting the reassembly.
Note the key in there now is what will be replaced
Picture of sprockets below
Thx
#2 Dusky
Dusky
  • 5,322 posts
Posted 11 August 2021 - 10:53 AM
Mark looks to be at +-1 o clock. That's where it's supposed to be too.
#3 Spider
  • 14,840 posts
Posted 11 August 2021 - 12:23 PM
Withe the Crank Key at 12 O'Clock, that'll be in the right place, then just line up the Dot on the Cam Sprocket with the Cam and Crank centres.
#4 postve
postve
  • 524 posts
Posted 11 August 2021 - 12:48 PM
Thanks so much guys I was assuming but wanted to be 100 percent
Edited by postve, 11 August 2021 - 12:49 PM.
#5 postve
postve
  • 524 posts
Posted 11 August 2021 - 05:28 PM
Quick point as something I noticed - here’s pics of it lined up but key on CAM sprocket is slightly off?
Note my twist ties solution for lining it up - in black
#6 postve
postve
  • 524 posts
Posted 11 August 2021 - 05:38 PM
Is this as simple as adjusting the small sprocket as thinking I just answered my own question
#7 Cooperman
  • 23,276 posts
Posted 11 August 2021 - 06:57 PM
With pistons 1 & 4 at correct TDC, you only move the cam sprocket until the dot lines up as close as possible with the one on the crankshaft sprocket. A straight edge through the centre point of the ends of the crankshaft and camshaft line up with the dots.
For more accurate cam timing and to remove the manufacturing tolerances, a DTI and crankshaft protractor are necessary together with the required offset woodruff key after the measurements have been made.
#8 postve
postve
  • 524 posts
Posted 11 August 2021 - 07:11 PM
Interesting was always advise never to move CAM sprocket, ok thx Cooperman, I will double check TDC by checking flywheel markings through dome hole and piston.  I checked Haynes and will use a metal ruler for spawn the two sprockets as well.
#9 Spider
  • 14,840 posts
Posted 11 August 2021 - 09:05 PM
Bit had to say for sure if it's aligned as per the dots would usually be from that angle, but keep in mind here too, that the dots when checked with a ruler across them and the centre line of the Crank and Cam seldom align spot on, they are usually a little off.
#10 postve
postve
  • 524 posts
Posted 11 August 2021 - 09:39 PM
Without touching CAM sprocket - which I am reluctant to even do - this is as close as I can get with keys lined up
Flywheel at TDC
Piston 1/4 at TDC
Edited by postve, 11 August 2021 - 10:08 PM.
#11 Homersimpson
Homersimpson
  • 829 posts
Posted 11 August 2021 - 11:03 PM
Its hard to say from the angle of the photo but it looks wrong to me, as mentioned above, a straight edge (like a ruler) run betwen the centre of the cam sprocket and the centre of the came sprocket shoudl be directly above the dot on each sprocket, when its all in line its fine.
As mention though there might be some degree of tolerance and it won't be exactly bang on but it should be fairly close.
I got this off an MG website but it shows the basic prinicple of what you are trying to achieve.
#12 postve
postve
  • 524 posts
Posted 11 August 2021 - 11:22 PM
Agreed and just throwing it out there as doing my dam best to line it up - issue is CAM sprocket is at 1pm but I am very reluctant to move it - as one thing I would have to take to my very expensive mechanic to re time- almost out of options and I cannot figure why it would not line
According to Haynes CAM sprocket generally at 2pm which would be perfect
#13 postve
postve
  • 524 posts
Posted 12 August 2021 - 01:42 AM
So Cooperman I can move the CAM shaft to line up as looks like a small degree or so to the left? I am worried I would have to get some to set up the CAM all over again - is this a fair concern?
#14 postve
postve
  • 524 posts
Posted 12 August 2021 - 03:46 AM
Ok, I rotate cam sprocket 1/4 inch now all lines up with piston 1/4 TDC and flywheel TDC.
But, dizzy shows 180 degrees out, should I flip around so rotor pointing at piston number 1?
#15 postve
postve
  • 524 posts
Posted 12 August 2021 - 11:49 AM
flipping dizzy around today and will slap it back together - see if she fires up..
