5X10 Dunlop Wheels: Originals Or Reproduction?
11 replies to this topic
#1 riktanius
riktanius
  • 233 posts
Posted 09 August 2021 - 08:34 PM
Is there a reason to not buy the reproduction version? Or is there a particular reason to buy the original "30" year old set?
The reproductions are cheaper and look nicer... but they should fit the same.
#2 mab01uk
mab01uk
  • 12,412 posts
Posted 10 August 2021 - 11:50 AM
The Mk1 forum 'experts' can usually answer any differences on later reproduction alloy wheel versions:-
http://mk1-forum.net/index.php
#3 sonscar
sonscar
  • 2,994 posts
Posted 10 August 2021 - 12:28 PM
In my experience "old" wheels can be very worn,not just wavering and out of round but the stud holes can be so worn as to never be able to balance them.New wheels should be free from all these defects but not always so.Choose wisely,Steve..
#4 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 10 August 2021 - 01:03 PM
I'd personally prefer to refurb an original set of wheels such as Dunlop D1s rather than buy reproduction ones, but originals in good enough condition are obviously a lot harder to come by than a brand new item which is ready to go off the shelf. Cheaper repro wheels can be of poorer quality and not quite match up to the originals - a common complaint I've seen mentioned quite frequently is that some of these cheaper aftermarket wheels can have a very poor standard of finishing (lacquer peel etc after minimal use).
#5 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 10 August 2021 - 02:19 PM
The originals are 4,5 at a different offset (ET value), not 5.
#6 r.tec
r.tec
  • 183 posts
  • Local Club: SfG Schoenau
Posted 10 August 2021 - 04:16 PM
Never heard or saw D1s 4.5" wide. I have a few sets of them, stamped all around '71 or '72, and they are all 5" and tell so on the inside: 5x10. They were one of the first aftermarekt wheels that had TÜV-blessing here. Later on Ronal and ATS had it too.
Do you have pictures/literature of the 4.5s?
#7 Maccmike8
Maccmike8
  • 1,101 posts
Posted 10 August 2021 - 04:17 PM
The rep D1s are 4.5 I think.
#8 riktanius
riktanius
  • 233 posts
Posted 10 August 2021 - 05:48 PM
I appreciate all the discussion.
I used Dunlop as an example, but I found some Cosmics that I think i will have to pull the trigger on.
Either way, my discussion was more about the difference between an older, unknown quality original, or a brand new reproduction. I am in NO WAY a purist, and I dont have an infinite wallet. But I do want to spend my money in the right place and not buy dud materials.
When I used to build Ricer racers in the 2000's, I knew what brands were good and what werent. But here we are talking about 50 year old wheels and I dont know if there is something that makes them special compared to the newer kind.
It will cost me 30ish% more for original wheels, tires, and reconditioning. I am happy to do it if it is the right thing to do. But I dont want to part with my cash just because it is "the purist way".
#9 r.tec
r.tec
  • 183 posts
Posted 11 August 2021 - 05:26 AM
You're right, it went a bit off-topic here.
If I looked for the D1 design I'd go the JBW route. They look nicer and are new. So one can be sure that they were not mistreated in the long history of 2nd/3rd... hand wheels.
#10 Spherix
Spherix
  • Just Joined
  • 479 posts
Posted 11 August 2021 - 11:44 AM
Just to complete the information: https://www.mini-for...-10-steel-rims/ the 5J version is listed as ultra rare, 4,5J being the norm.
#11 r.tec
r.tec
  • 183 posts
Posted 11 August 2021 - 01:40 PM
No, Spherix, D1 are the aluminium alloy wheels numbered LP922 or C-AHT184 when from Special Tuning.
Your are referring to steels, LP918, C-AHT182. They indeed were nearly all 4.5x10.
#12 Spherix
Spherix
  • Just Joined
  • 479 posts
Posted 11 August 2021 - 03:32 PM
Ah, I figured when the OP referred to 30+ year old sets, by default they meant the LP918.. Suppose the 1990's is 30 years ago now..
