Hi everyone - hoping that someone can point me in the right direction as this problem is driving me crazy.
Problem - I have oil fouling the spark plugs on ALL cylinders so bad that it kills the spark within a minute or two of running. I took the head off at the weekend, checked for a warp, replaced the valve seals and the head gasket. There was an incredible amount of oil in every cylinder. Same problem when I tried running it after the new gasket and seals.
The engine was rebuilt - rebored, new pistons and rings put in about 2k miles ago. Ran a compression test this morning and I got (in psi from cylinder 1-4): 160, 165, 180, 170.
Before I rip the engine out and strip it to find the cause, does anyone have any ideas?? Could an oil pressure regulator sticking open cause this? At my wits end.
