Hi All,
I'm thinking of changing my camshaft for a Minispares Evolution001 (in a standard 998 with Stage 1 exhaust and twin HS2s). I know this is a topic that will have been discussed many times before, but I can't find the info I'm after.
I'm not looking for advice/opinions as to whether or not it's worth doing - I'm hoping to benefit from your collective knowledge/experience as to the actual practicalities of it. My questions are:
1) Will duplex timing gears fit straight in with the standard timing cover I've currently got? (I think it should, but want to check as I have seen mention of 'duplex timing covers').
2) Am I correct in thinking that I will be able to remove and replace the followers via the plates on the back of the engine?
3) Can I determine, before taking it apart, whether/what offset of woodruff key I will need?
4) Are there any other components (e.g. locktabs, seals etc) that I will need to replace while I'm at it? (I'm aware of the 'triangle plate' and timing cover gasket and will replace these).
5) I'll purchase a timing disk and some assembly lube, but are there any other 'special' tools I will need?
If you have any other hints or tips, I'd be glad to hear them!
Thanks in advance,
Dan
TheHippo
