I did inside the boot first
Then the back panel
Then started working down the sides
I didn't photograph that specifically but it can be seen in the pictures that follow.
The riv nit pliers arrived so I got the rest installed for the arches.
And that's that done
Next the ones for the grille
Before I try the grille I am going to modify the front panel slightly.
There is a relief in the front panel Both sides which is to allow the top screws that hold on the side trims to go in without bottoming out kn the bodywork
Trouble is, the relief isn't really deep enough to allow the use of screws that are long enough enough hold it properly so I have drilled a 6mm hole each side which once painted will be safe from wet but allow the screw to go through without damaging the paint.
Then the grille can be trial fitted
Next, riv nuts for the headlamp bowls
And then riv nuts for the relay/fuse block
Now I need to remove all that lot and do a heap of sanding and then I can paint it.
Ben
