Rover Mini Mayfair Restoration @ Mill Road Garage Iow
196 replies to this topic
#151 MikeRotherham
MikeRotherham
  • 976 posts
Posted 14 October 2021 - 05:31 PM
Ben, do your colleagues at the garage ever come over and see what you are producing and comment or are they so used seeing it?
#152 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 October 2021 - 05:37 PM
I get occasional comments but I think they don't tend to pay too much attention as they are usually flat out constantly as we are always very busy.
Ben
#153 Colinmac1330
Colinmac1330
  • 257 posts
Posted 15 October 2021 - 08:45 AM
What grit of sandpaper do you go down to before the polishing? I have 2000 grit but I see there are lower ones available.
#154 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 October 2021 - 09:30 AM
I use 3M 2000 grit wet on a block and by hand initially to flatten the paint right off.
Then I use Norton ice foam discs to finish off.
The discs are to go on a random orbital sander but I find using them that way leaves pig tails in the paint which takes an age to polish out.
Instead I use the discs by hand starting off with the 2000 grit wet and finishing with the 3000 grit wet.
It works well for me.
Ben
#155 Colinmac1330
Colinmac1330
  • 257 posts
Posted 15 October 2021 - 09:34 AM
Thanks Ben, if it's good enough for you it's good enough for me!  :gimme:
#156 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 October 2021 - 09:38 PM
Only a small amount of progress today as we have builders in that are creating an extension to my workshop.
Exciting times!
I have got a bit more polishing done though in between dealing with that.
Ben
#157 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 October 2021 - 09:01 PM
Time to start reassembly.
Im Going to need subframes so I better paint them
Front one is the original sandblasted and etch primed. Rear one is a new heritage item.
Now onto the shell.
First job is to fit the antidrum.
Here is one side done.
And then both sides complete
Not forgetting the quarter panels
I've run the fuel and brake lines and out a few small parts into the engine bay as I was unboxong and sorting through
I've also run the front to rear wiring looms.
I'm going to fit the main loom Ince Ince engine is back in place.
Just need to build up and fit the subframes next.
Ben
#158 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 21 October 2021 - 06:27 AM
Come on crack on there's a queue forming ;D
#159 MikeRotherham
MikeRotherham
  • 976 posts
Posted 22 October 2021 - 02:46 PM
I think that rear subframe now is going to last longer than me.
Does it say 'MOWOG' on it? I can't quite make it out
#160 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 October 2021 - 02:49 PM
It does say mowog.
I can't recall seeing that on the previous new frames I have used.
Ben
#161 MikeRotherham
MikeRotherham
  • 976 posts
Posted 22 October 2021 - 03:49 PM
Thanks.
Edited by MikeRotherham, 22 October 2021 - 03:59 PM.
#162 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 29 October 2021 - 11:42 AM
Apologies for the lack of updates lately.
It's been hard to find the time unfortunately.
Here we go.
The front sunframe was built up and installed
Followed by the rear
And then I finished the building up by installing the radius arms and front hubs
And now it's rolling
Fuel tank in
Then the headlining
Windscreen
Rear screen
I'm waiting for a fillet strip for that one
Rear quarter windows
Headlamps
And now to smarten up the engine ready to install
I removed some of the ancillaries and covers
And then once cleaned and prepped, I gave it a coat of acid etch
Followed by a fresh coat of red
And then the chain cover and some other parts
Just needs reassembling and it can go in.
Ben
#163 MikeRotherham
MikeRotherham
  • 976 posts
Posted 30 October 2021 - 07:21 AM
How something as simple as a repainted A series engine rocker cover could look so good. 'Tis a thing of beauty
#164 bangermadness08
bangermadness08
  • 258 posts
Posted 31 October 2021 - 03:31 PM
can you give out some tips of fitting headlining? mine has a webasto sunroof so its a bit more fiddly. I've fitted my one myself but made a dogs dangles out of it, used all purpose glue but found that quite messy
#165 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 October 2021 - 05:25 PM
Cleanliness is very important and so is patience.
I use spray glue usually but you have to sheet up if you don't want it all over the inside of the car.
Fabric headliners are easier to fit than vinyl ones as they don't need to be hung prior to stretching and gluing.
Refitting used headlining as in the case of this car is very tricky and very difficult to get perfect. I would advise against it unless it's in perfect condition and make sure you clean off all of the old glue before attempting to glue it.
Hang the liner on the rods from the cant rails, stand the rods up one at a time so the curve follows the roof. You will need the felt glued to the inside of the roof skin for the rods to wedge against or you will struggle to keep them up the right way. They like to fight against you stretching the liner and fall over which is frustrating.
Pull the liner tight to the rear window opening and clip up with strong bulldog clips, then do the same at the front making sure the liner is straight. Then do the same to the side openings.
Keep adjusting until you are happy.
When ready to glue, unclip the bulldog clips from the back opening and spray along the edge of the liner and along the top of the window rubber lip.
Wait until the glue is dry to the touch and then stretch it back into place and press firmly making sure you don't get any creases and it stays square. If you need to reposition, do so quickly.
If you have let the glue dry before sticking into place, you shouldn't need to use the clips to hold it again, it should stick instantly.
Repeat this on the other openings trimming the excess as you go.
Thays only a rough idea as it would take an age to write it down in a way that makes perfect sense so I hope it helps you out.
Ben
