E10 Fuel
34 replies to this topic
#16 Vanman20
Vanman20
  • 274 posts
Posted 08 July 2021 - 09:03 AM
I'm going to switch to E5 super unleaded,might even see a small improvement in performance
#17 Maccmike8
Maccmike8
  • 1,101 posts
Posted 08 July 2021 - 01:37 PM
Yeah Il go Super too. For the small amount of mileage Il do it wont hit me too hard.
#18 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 08 July 2021 - 04:55 PM
Depending on the compression ratio and cam combination you can actually work out to be better off using the more expensive fuel.
Ac
#19 unburntfuelinthemorning
  • 1,983 posts
Posted 27 July 2021 - 10:59 AM
Even my lawn mower prefers Esso super unleaded.  Stopped popping and spluttering when I switched to it.
#20 bpirie1000
bpirie1000
  • Area Managers
  • 2,345 posts
  • Local Club: Amoc
Posted 29 July 2021 - 04:26 PM
Well my tank of petrol has lasted since 2007.
Not been anywhere right enough... but great i probably have a tank of syrip now..
#21 richmondclassicsnorthwales
  • 942 posts
Posted 29 July 2021 - 06:38 PM
Fiat actually made a car to run on pure Ethanol - that's I suppose where it all went (stit pu) - read it backwards
So with that in mind, the world looked on and thought, what a great way to screw motorists, get them to pay full rate and put 10% shyte in it, more for us fuel companies
It may ease carbon emissions, but it does not help the classic car
E10      It absorbs water, that's the damaging part, and water and aluminium - we all know what happens there
Also contains sugar particles, we know what sugar does too, apart from make people fat !!!
You are as Moke says, paying for cat ssip, and that in a nut shell is what it is
Just got to try and up our game, Governments don't give a flying kcuf, - less free road tax for historic vehicles because they can kcuf them up
Gets all petrol cars off the road, enabling them to push electric through and through
Stay one step ahead...................................
#22 Spider
  • 14,846 posts
Posted 29 July 2021 - 08:44 PM
I'm pretty sure running engines on pure, or new that, Ethanol isn't new. I'm not sure when that Fiat engine was done and run ??? however, it's been used in Drag Cars going back at least to the 60's.
In the closing days of WWII the Japanese had such little Oil left that they couldn't afford to use it as fuel, so for their Mitsubishi Zeros, they were stripping whole mountains of bamboo and making fuel from that, which I'd guess would be similar to Ethanol.
If the Car is designed from the outset to run on a particular fuel, then sure, that's gotta be a good thing. Our Cars, from start to end were never designed for Ethanol or Ethanol Blends.
To run an IC Engine on straight Ethanol, the fuel / air mixture is around the 5:1 mark (from memory) and it doesn't return anywhere near the same MPG, so a tank of fuel won't take you far.
#23 richmondclassicsnorthwales
  • 942 posts
Posted 30 July 2021 - 10:44 AM
Interesting
I wonder why they don't tell us what methods they use to get the Ethanol. I do believe Moke your right on the Bamboo,  it is this I understand where it comes from.
Can't see someone with a hand saw taking it down ??
If I remember it was in the early 70's when the Italians tried it, I suppose a method for something else when the Suez crisis was about
With regards to running IC Engines on the gear, as you say, if it is designed to run with it, all fair enough, but again, no they are not
Closing words on the matter
Poor Pandas !!!!
#24 Spider
  • 14,846 posts
Posted 30 July 2021 - 11:55 AM
As in where it comes from ?
I don't know if it's universal around the World, but the cat's pee they use here to blend with the real stuff they make from Sugar Cane.
Sorry, I'm gunna drift a little off topic, but it's all related.
The boffins somewhere worked out that if around 80%+ petrol users here in Australia took up with E10 (we don't have E5 here), our stocks of Sugar and the Cane that it comes from would be depleted in something like 6 months, so, on that front, without imports, it's hardly sustainable for use to use it in any quantity.
The other aspect of us here in Australia using Ethanol, that comes from Sugar Cane is we are the driest Continent on Earth, we don't have enough rainfall to support our ever growing population, so we all have water restrictions and Desalination Plants,,,, all this while we are effectively burning a good bit of our (rain) water in our cars,,,, makes perfect sense (not).  It really send me in to orbit,,,
#25 Dusky
Dusky
  • 5,322 posts
Posted 30 July 2021 - 07:32 PM
That's environmental logic. Import sugar cane with big diesel containers ships to use for alcohol in cars. Like burning gas and coal to charge a Tesla.. :)
#26 richmondclassicsnorthwales
  • 942 posts
Posted 31 July 2021 - 08:52 AM
Bonkers isn't it !!!!!
#27 Spider
  • 14,846 posts
Posted 28 November 2021 - 04:40 AM
I believe it corrodes the metal fuel lines and also the float bowl on the Carb.
It's cat's pee.
Here's an experiment I'd encourage the guys who are thinking of going over to E10 carry out.
Put some in a seal jar for a few weeks, check on it daily and perhaps even take photos each day to track what's happening.
Not my experiment, but this is E10 after 20 days.
It might be fine in a newer car that's driven daily, but in our Classics that may stand for a few weeks at a time, it's not so good. Remember too, the fuel pick up in your fuel tank is at the bottom.
#28 Mito
Mito
  • 415 posts
Posted 28 November 2021 - 08:24 AM
That's quite a poorly designed experiment. Where's the E5 and no ethanol fuel for comparison?
#29 PoolGuy
PoolGuy
  • 848 posts
Posted 28 November 2021 - 09:53 AM
Thanks for that Spider, my van will be sitting for a few days this week, so I’ll check the Filter King bowl in a few days.
#30 Spider
  • 14,846 posts
Posted 28 November 2021 - 10:48 AM
While this was not about E5 and 'standard' fuels, maybe include those tests in your experiment and post up the results here.
