E10 Fuel
34 replies to this topic
#1 Aly-g
Aly-g
  • 459 posts
  • Local Club: Still looking
Posted 03 July 2021 - 11:48 AM
Just wondering if anybody has thoughts about e10 fuel coming in September this year ? How will it affect our old cars, I read that cars with variable jet carbs are OK but other carburettors will have problems, also the ethanol will rot fuel tanks and fuel lines.....!
ALLAN
#2 nicklouse
  • 18,581 posts
Posted 03 July 2021 - 02:53 PM
Loads of thread on here about it.
things to change. Rubber hoses, fuel pump. And the float chamber seal, valve if not made from suitable rubber.
or just use the 98 Octane fuel.
#3 Aly-g
Aly-g
  • 459 posts
Posted 04 July 2021 - 11:54 AM
Thanks nicklouse, I did look but I think it was a case of looking but not seeing..! And I think I posted in the wrong place as well, it comes to us all in the end,( old age that is ) looking forward to next Thursday when my mini gets delivered.
Allan
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 05 July 2021 - 10:53 AM
I've moved the topic.
There's all sorts of classic cars and motorcycles that will have to run 98 Ron.
I wonder if it'll lead to any other issues?
#5 Spider
  • 14,846 posts
Posted 05 July 2021 - 11:10 AM
I believe it corrodes the metal fuel lines and also the float bowl on the Carb.
It's cat's pee.
#6 whistler
whistler
  • 1,791 posts
Posted 05 July 2021 - 11:45 AM
I've just spoken to Burlen (SU) about their products regarding E10 and I was told that they foresee no problems and that their maintenance kits can cope with modern fuels. They will be revamping their website later this year and updating the info on there. As usual they are very helpful on the phone.
#7 Spider
  • 14,846 posts
Posted 05 July 2021 - 07:24 PM
One other specific item that maybe easy to overlook is the fuel pump, particularly if it's a mechanical one. They have a Rubber Diaphragm in them which will likely rot, unless it's fairly new.
I believe it corrodes the ,,,,,,,,,,, and also the float bowl on the Carb.
I'm aware that the current SU Kits have components that are E fuel compatible and have been for a couple of years now. In regards to the Fuel Bowl, as the E Fuels contain a lot of water it's that that I believe does the damage here. I know from Carbs I've pulled down to overhaul, any that have had any water in the Fuel (that ended up in the Bowl) there's always as a minimum, white powder coating the lower parts of it and where it's been there a while, they end up with pin holes in them.
#8 T.Harper
T.Harper
  • 714 posts
Posted 05 July 2021 - 08:24 PM
Some fuel stabilisers and lead additives claim that they stop water retention so this is worth considering.
#9 nicklouse
  • 18,581 posts
Posted 05 July 2021 - 08:30 PM
Don’t forget the pressure regulator if fitted.
crispy.
#10 Cooperman
  • 23,278 posts
Posted 06 July 2021 - 10:01 AM
Just stick with E5 and all will be fine. There has not yet been any suggestion that E5 will not continue to be available.
#11 hunterg30
hunterg30
  • 349 posts
Posted 06 July 2021 - 12:04 PM
there are ways to remove ethanol , using water is one of them, just need to add octane booster afterwards,, plenty of vids on how to do this
#12 mini13
mini13
  • 3,810 posts
Posted 06 July 2021 - 12:24 PM
basically just replace all the rubber bits that you should have already replaced and you should be ok, and fit a fuel filter while our at it.
#13 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 06 July 2021 - 02:33 PM
Government will both ways: E5 will only be available as the higher priced super fuels which bring in extra tax and E10 will see consumption rise as it's less efficient so you use more and pay more tax! Sneaky!
#14 Andosoft
Andosoft
  • 15 posts
  • Local Club: Nsw
Posted 06 July 2021 - 11:09 PM
Some interesting info here along with a book which has some testing and actual technical data with recommendations.
https://classicengin...MENU_MainMenu=5
The good being it shows some better performance if tuned correctly. The bad - well pretty bad if you get water in the fuel system :o
https://classicengin...ainMenu=1000001
#15 ArnieWallace
ArnieWallace
  • Just Joined
  • 18 posts
Posted 07 July 2021 - 09:30 PM
This might be of interest.
