Air Filter Socks
Posted 25 June 2021 - 04:07 PM
https://www.minispar...|Back to search
Posted 25 June 2021 - 05:15 PM
I use ITG socks.
Posted 25 June 2021 - 05:22 PM
Posted 25 June 2021 - 06:09 PM
How are they held on a tie wrap?
I have heard a few horror stories about them getting sucked in. I guess they would be a cheap version?
Posted 25 June 2021 - 07:18 PM
I use ITG socks.
What size Nick?
Posted 25 June 2021 - 07:48 PM
Posted 25 June 2021 - 07:52 PM
Minimum distance from the end of the ram pipe is 20mm. And then a cable tie to fix. They are 3 layer on the sides and end and I think too stiff to be sucked in, as you say probably a cheap version. I am also using pipercross full radius 60mm rampipes so the tie pulls it tight under the radius
And how thick is the foam on them. I guess about 20mm?
Posted 25 June 2021 - 07:56 PM
Posted 25 June 2021 - 08:34 PM
Posted 25 June 2021 - 08:37 PM
I use ITG socks.
What size Nick?
Sorry no idea.
don’t forget you also need clearance from top of sock to any solid surface.
Posted 27 June 2021 - 09:29 AM
I have them on my racer only issue I had once was starting it up, (always with bonnet off) the weber spluttered and f@rted and popped back and set one on fire... it was a tiny fire easily put out by my hand whacking the foam filter...once the car is running of course it doesnt pop back through the carb...just something to be aware of..... I always start mine bonnet off so I can see whats going on
