Thanks for all the advice👍👍
Subframe Painting
cristiano1968
, Jun 24 2021 12:54 PM
20 replies to this topic
#16
Posted 25 June 2021 - 04:00 PM
#17
Posted 25 June 2021 - 06:48 PM
I would,also add that hammerite is not as good as i used to be...
I may also add that if you have had the subframes blasted give the frames a once over with some sand paper/scotchbrite to give the surface a chance of sticking to the metal..
Blow it over properly with compressed air and makemsure no blasting material or sanding dust gets in there...
Like with bodywork.. all in the time spent preparing....
I would add waxoil after it has been painted for some months, allowing the paint time to dry.. before being taken on the road..to repel water and protect.
#18
Posted 25 June 2021 - 07:00 PM
The as blasted finish should be the best finish you can get for paint adhesion,provided it is not dusty.Wash it down with panel wipe.Steve..
#19
Posted 25 June 2021 - 07:07 PM
yes I was going to go over it with sandpaper maybe 800 grit or higher
#20
Posted 25 June 2021 - 07:14 PM
I also thought that the sandblast was enough for primer/paint adhesion
#21
Posted 25 June 2021 - 07:49 PM
Would say depends what meda was used to blast it...
I have seen some horendous finishes, but also seen some great work....
Make the informed decision....
