Electronic Distributor And Coil
12 replies to this topic
#1 Shylos
Shylos
  • 545 posts
Posted 07 June 2021 - 07:44 PM
Hi, I am looking at changing my stock dizzy for an electronic ignition and want to make sure I order the correct parts.
I have a 1990 998 City, and while the engine block was replaced going by the number it is still, according to Calvert's site, a "998 A+ block with centre locating tang in main cap, 1985 onwards"
Am I right in thinking this distributor will work? C-27H7701 - Mini distributor electric evolution performance to 276 cam profil (minispares.com) along with this coil
GCL143 - Mini coil for electronic ignition - '89 on (minispares.com)
I'm in the US and ordering parts to be shipped out so want to make double sure. That dizzy is out of stock at the moment but if I know that is the right one at least I will be sure if what I need.
Thanks for any help!
#2 dotmatrix
dotmatrix
  • 439 posts
Posted 07 June 2021 - 07:59 PM
which dizzy do you have?
#3 Shylos
Shylos
  • 545 posts
Posted 07 June 2021 - 08:05 PM
I assume a 59D based on the vehicle model/age, I haven't checked for sure as it looked easier/cheaper to replace the whole thing based on that price than use a kit.
#4 Shylos
Shylos
  • 545 posts
Posted 07 June 2021 - 08:19 PM
This looks to be a TrueSpark equivalent available in the US which ay be a better/quicker option.  Distributor, A+, w/ Electronic Ignition Pickup (59D4E) | Seven Classic Mini Parts (7ent.com)
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 07 June 2021 - 08:54 PM
65D but get it recurved to suit the 998
#6 Tornado99
Tornado99
  • 750 posts
Posted 07 June 2021 - 09:32 PM
Whole dizzy is cheaper than an EI pickup plate to replace points plate? That seems out of whack!
My '88 has a US made Pertronix Ignitor II kit fitted to a 59D original distributor.
#7 Shylos
Shylos
  • 545 posts
Posted 07 June 2021 - 10:39 PM
Maybe I am getting confused, it is definitely possible...
I was comparing this:
http://www.minispare.../C-27H7701.aspx
with this:
http://minispares.co...rts/LU143A.aspx
and then looking for alternatives on the 7ent site
#8 Shylos
Shylos
  • 545 posts
Posted 07 June 2021 - 10:43 PM
Is this what you have? Ignitor 45D or 59D (LU-143A) | Seven Classic Mini Parts (7ent.com)
#9 croc7
croc7
  • 809 posts
Posted 07 June 2021 - 11:21 PM
If you have the original Lucas distributor body and baseplate, it would be better to keep it and install a Pertronix or H & H electronic ignition module.  At least you would be assured of the build quality.
#10 Tornado99
Tornado99
  • 750 posts
Posted 08 June 2021 - 02:45 AM
That looks like the Ignitor 1, I have Ignitor 2 (Red in colour) which has several improvements including power modulation to prevent over heating if ignition is left on with engine shut down.
There is also Ignitor 3 which adds rev limiter and some othe bells and whistles.
#11 andyapanel
andyapanel
  • 624 posts
Posted 08 June 2021 - 11:45 AM
Try emailing Minispares; they are very helpful.
I see you live in Minnesota. Do you drive the mini in winter?
#12 Shylos
Shylos
  • 545 posts
Posted 08 June 2021 - 01:03 PM
That makes sense, thank you.
Ah I see, thanks. I looked at the Ignitor 1 as it specifically said 59D but it looks like the 2 will be appropriate too, thanks for the information!
No I haven't, in fact it has been in storage since I shipped it out here as it was just before COVID came along. Hopefully it will be on the road this summer, and then I will winter it in a garage every year.
#13 Shylos
Shylos
  • 545 posts
Posted 09 June 2021 - 07:12 PM
Thanks for the help everyone, between this and contacting Mini Spares I am good to go!
