Restoring the wifes' '88 Mayfair, it has a factory sunroof fitted.
Factory Tilt Sunroof.jpg 45.58K
0 downloads
Now, a couple of things I'd like advice on.....
Firstly, it's the only piece of glass still in the car which is due a respray shortly - will I be opening a can-o-worms if I attempt to remove it for said respray? It seems to be bonded-in with some kind of sealer too.
Sunroof Seal and bonding1.jpg 41.04K
1 downloads
Secondly, whilst the headlining is in very good nick and I have avoided removing it during the resto because I know I'd never get it back in anywhere near as nicely the edge of it on the drivers side has come away slightly from the sunroof seal, is it possible to get it back in or again is it a case of taking the sunroof out and all the possible problems that may result? Are seals available if I bugger this one up?!!
Sunroof view of passenger side.jpg 162.74K
2 downloads
Sunroof view of drivers side.jpg 52.15K
1 downloads
Have any of you experienced this and if so what did you do (successfully)?
Useful suggestion gratefully received!
Paul.
