The plumbing analogy holds true.
If you connected 2 tanks the water level (which you could measure as head or pressure & equates to voltage) would equalise eventually regardless of how small diameter piping you used. If you put a tap in the middle of that pipe & ran a hose & nozzle from it, the more you opened the tap the farther the water would squirt, but the range would also be limited by the height of the tank(s) & the size of the pipes.
If the pipe to one tank was bigger than the from the tap to the other, it'd start by emptying quicker, but the more the water level got lower than the other tank the faster the fuller tank would would empty.
OK I think I made a basic mistake in trying to measure a voltage drop by placing the voltmeter in series with the ballast resistor wire. As I've now come to understand, a voltmeter has a very high internal resistance, so by placing in series, it is effectively making an open circuit, no current flow and no voltage drop. I need to place the meter in parallel to the ballast wire and measure resistance, not volts. So I need to find the other end of the pink/white wire. Or for easier access, according to the wiring diagram, the white wire at fuse #1 should connect to pink/white at the ignition switch....so should be able to hook one multimeter lead to the white line at fuse, other lead to the pink.white at coil....and see resistance across the ballast line...
EDIT: And doing the above, I see a nice 1.3 Ohm resistance on the ballast pink/white line.
So it appears my FT2 coil, 0.6 Ohm, running with non-ballast, 12v feed line failed with an Ignitor 2 EI. If this is the proper setup for this coil, then it just failed for reasons other than over loading. It is the liquid filled version...so maybe high vibrations contributed. There is an epoxy filled version for better resilience.
Edited by Tornado99, 25 May 2021 - 04:56 PM.
