Looking to purchase a spot welder but there are a few knocking around the market and not sure which one to buy, and what accessories I will need as in size of arms. Any help would be appreciated.
Posted 22 May 2021 - 02:16 PM
Posted 01 June 2021 - 09:28 AM
under this link at the very bottom you find an "ARO welding guide" which contains all the required arms as well as the instructions where to use which one.
http://mk1-performan..._paint&body.htm
Posted 01 June 2021 - 05:03 PM
I bought the 16amp Clarke one, did my mk2 project no problem, I bought some longer arms and made some electrodes myself from copper bar for some awkward areas, but it performed very well. It takes a little thought to get to some places but was fine, I had to plug weld a few areas due to not having correct arms but they are expensive for a one off,
Posted 01 June 2021 - 08:00 PM
Posted 02 June 2021 - 06:24 AM
Posted 02 June 2021 - 02:39 PM
Edited by Johnmar, 02 June 2021 - 03:43 PM.
Posted 07 June 2021 - 11:30 AM
Is it correct to assume that if used at home a 16A spot welder would need to be high power supply (e.g. cooker circuit) and would not run off a standard 13A feed?
You assume right. My circuit breakers (even the 16A/400V supply) kept going off. So in the end I plugged into my electrical emergency heater supply which has 3 phase 400V fused with 50A each. Now it works great with that 5-terminal 6mm2 extension cable. Don't ask if this is safe to do for the DIYer, I am trained on such matters.
Posted 07 June 2021 - 05:39 PM
