Minispares New Alloy 1275 's' Cylinder Block Running...
8 replies to this topic
#1 mab01uk
mab01uk
  • 12,327 posts
Posted 22 May 2021 - 07:44 AM
Minispares alloy block is now on their Instagram....
Video in link of Minispares new alloy 1275 'S' cylinder block running on one of Swiftune's engine dynos:-
https://www.instagra...g_web_copy_link
Screenshots from the video below
#2 mab01uk
mab01uk
  • 12,327 posts
Posted 01 June 2024 - 09:52 AM
Mini Spares goodies on display at IMM 2024...
https://www.facebook...28&locale=en_GB
#3 Shooter63
Shooter63
  • 997 posts
Posted 02 June 2024 - 11:12 AM
I was at Minispares HQ a few weeks ago picking up some bits and had a chat about the alloy block, it was used as a test piece to make sure everything was OK, the actual blocks are cast iron, one of which is next to the alloy one on the stand, I had a quick poke around the iron one, it's very well produced and aimed at the high spending Appendix K crowd.
Shooter
#4 DeadSquare
DeadSquare
  • 3,070 posts
Posted 02 June 2024 - 03:31 PM
If "They"  ---  somebody, makes an aluminium block, it needs the bores spaced for 74mm pistons and plenty of metal on the face to take a longer stroke or for drilling and tapping to take the studs for a twin-cam head.
#5 Shooter63
Shooter63
  • 997 posts
Posted 02 June 2024 - 08:11 PM
Something similar to this then?
Shooter
#6 imack
imack
  • 2,042 posts
Posted 02 June 2024 - 08:22 PM
I saw the Ascaso A5+ block and crank at KAD. Beautifully engineered, but eye wateringly expensive, and that's before you add a KAD 16v head to it.
#7 DeadSquare
DeadSquare
  • 3,070 posts
Posted 02 June 2024 - 11:06 PM
Shooter
Mmmmm,   isn't that what we have always dreamed of ?   Have they sold any ?
I wonder how much those cranks cost ?   and where the BMW thrust bearings are fitted ?
#8 imack
imack
  • 2,042 posts
Posted 03 June 2024 - 04:46 AM
KAD told me block, rods, crank & pistons were in the region of £20k. That was about 18 months ago.
#9 DeadSquare
DeadSquare
  • 3,070 posts
Posted 03 June 2024 - 11:49 AM
I once saw about a dozen, Longbridge, small-bore, aluminium blocks, in a Wolverhampton scrap-yard.
To my utter grief, they had all been stood on end and the front and rear main bearing webs, smashed with a sledge hammer.
