1998 Mpi Clutch Slave Cylinder Removal
6 replies to this topic
#1 Alexxx
Alexxx
  • 49 posts
Posted 11 May 2021 - 09:28 PM
Hi Folks,
Trying to replace a seized clutch slave cylinder, so far I have only managed to remove one top bolt that is towards the front of the car. I cannot get a socket onto the rear bolt, just no space. I think getting the hydraulic hose off looks seriously difficult, maybe not even possible in that space.
Is there a particular method? like remove the whole mounting plate? Does not leave much room to get a spanner on the hose fitting way down there.
Any advice appreciated.
Regards
#2 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 11 May 2021 - 10:44 PM
My car is 1989. Not sure if there's a set way to do this but hers my method;
I did this recently by
1. removing the screen wash bottle and 2. the brake master (not the servo.)
Then I found an old 9/16 cranked ring spanner and cut it down to 2/3 of its length with an angle grinder. This fitted into the space nicely without having to remove the plastic air duct.
I cut the Flexi hose off as I was renewing it anyway.
It's pain having to bleed the brakes after reassembly. When you reassemble, remember to connect the new Flexi hose before bolting down the slave cyl.
Good luck.
Edited by Richard_, 12 May 2021 - 06:21 AM.
#3 Bobbins
Bobbins
  • 1,485 posts
Posted 12 May 2021 - 06:06 AM
Remove the whole mounting plate, it'll likely need a de-rust and painting anyway.
#4 shough
shough
  • 196 posts
  • Local Club: N/A
Posted 12 May 2021 - 08:29 AM
This might help you out.
https://youtu.be/TAm20UzeKzY
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 12 May 2021 - 08:42 AM
on the mpi is deafo not a nice job to do..
Persevere and if in doubt remove it......
#6 Alexxx
Alexxx
  • 49 posts
Posted 13 May 2021 - 09:14 PM
Thanks folks,
I had to remove the whole bracket in the end, a very slow job.
One of the most awkward jobs i've ever done.
But it did bleed very easily and I have a working clutch so all is good
#7 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 13 May 2021 - 09:42 PM
Excellent result.
