Steering Rack Hack?
35 replies to this topic
#31 AlasdairM
AlasdairM
  • 240 posts
Posted 22 May 2021 - 08:59 PM
Attached File  9F05DFA2-A888-44E6-9793-CD4F67C86CB0.jpeg   62.1K   1 downloads
Yeah my housing looks like this, so I’m a bit worried it will need a lot of washers/longer bolts etc.
#32 nicklouse
  • 18,576 posts
Posted 23 May 2021 - 09:02 AM
If you are going to add a stabiliser at the Rad end then get the DSN one don’t bother with any of the others they are just a pain and are crap.
https://www.dsnclass...-big-bore-long/
don’t forget the spacer that is mentioned in the text.
#33 AlasdairM
AlasdairM
  • 240 posts
Posted 25 May 2021 - 12:00 PM
Do I need to drop the engine/subframe to replace the front-rear subframe mounts? Or can I just jack the body up, and hope I can wiggle the old mounts out?
thanks
#34 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 25 May 2021 - 12:46 PM
I've done them without loosening the tower bolts, by having two people; one tries to put bolts through the holes, while the other levers with a screwdriver/tire iron. There's often quite a bit of force on them in situ, so it's not an easy job by yourself. Don't hammer any bolts through as you'll damage the thread.
#35 MMM1965
MMM1965
  • 93 posts
Posted 09 June 2021 - 08:52 PM
Changing the whole rack isn't too difficult a job really, just take your time, follow the haynes manual and you can't go wrong really. If i can do it anyone can do it honestly.
#36 ac427
ac427
  • 674 posts
Posted 24 May 2022 - 11:21 AM
thanks
A bit late but...
When i let the clutch in on gear changes the was a bang. It turned out the lower engine steady bar had failed at one of the ends. It looked fine in situ but with a bit of prying you could see where it had broken off at one end.
As standard i think there are two engine steadies, one on the top at the flywheel end and the other below at the water pump end of the engine.
I replaced that the lower one and added one on the other side. i didn't bother with the thermostat end top engine steady because of the extra work involved, instead of just bolting something on.
